I have a video quality problem. The picture is very blocky as the bit rate isn’t good enough in certain high detail frames. But this only happens when playing live TV via Plex.
When the picture looks excellent:
TV Antenna -> Samsung 4K TV as direct signal input
TV Antenna -> HDHomeRun Duo -> 1Gb switch -> Samsung 4K TV
TV Antenna -> HDHomeRun Duo -> Netgear R7000 Router -> Intel NUC with Intel i3 running Plex Server and Plex Player on Web browser
When the picture looks bad:
TV Antenna -> HDHomeRun Duo -> Netgear R7000 Router -> Intel NUC with Intel i3 running Plex Server on Windows 10 Home -> Netgear R7000 Router -> Roku Ultra Running Plex App -> (HMDI) Samsung 4K TV
The Plex server reports that it is streaming to the Roku Ultra as MPEG2VIDEO 720p hw. All ethernet connections are wired so there is no wireless involved.
I just upgraded my Roku to the Ultra and that didn’t help. What should I do next?
After summarizing the problem I thought about it and changed the Roku display setting to 720p to match the incoming stream. It had been on HD 4K @ 30 Hz. Now the picture is watchable. It is still a 720p image stretched to my 55 in TV but it is much better.
As I watch closely, when the camera pans, the edges in the image look like it is an interlaced video stream. Football isn’t on until Saturday and that will be the ultimate test when the camera shows the crowd.
Assuming you’re using the HDHomeRun App on Samsung = Also Not transcoding
Pretty sure not transcoding as PC is capable of MPEG2 natively
Pretty sure this is transcoding, as most New devices and TV’s no longer support MPEG2 (My Sony TV, and my Amazon Firestick 4K has the same issue)
HW at the end = Hardware Transcoding, Are you using an AMD Card, an NVIDIA Card, or the Intel QSV on your processor for the transcode? Do you know?
AMD Is terrible at x264 transcoding. NVENC is better but still not ideal. QSV from what I understand is better. Maybe also try disabling Hardware transcoding altogether to see if the resulting picture is any better?
That’s all I got. I hope you figure it out, hopefully I’ve helped you narrow things down a bit
