There was a problem saving your DVR. Please try again
Server Version 1.25.1.5286:
Tuner Make/Model: xTeVe
Using XMLTV?: yes
After recent update I can no longer get the DVR work with my xTeVe.
initially I could not get into settings of DVR at all (just blinked and then reffered me to forums).
Then I was quick enough to click delete dvr and now I can get into settings.
Problem is now I cannot seem to be able to add the tunner.
adding path to xml epg file, it lists all channels, and no matter how many channeles do I selected, either 1 or more, it just saying:
I’ve changed the debug logs ot verbose, but could not find anything that fails that can indicate this (or maybe I 'm not looking in the right place).
Please help, I can no longer use the DVR of this app.
I managed to solve this after debugging with chrome developer tools.
Seems this issue is related to fact the feature does not work from running within ip or local host.
To make it work, you must access it via url of “https://app.plex.tv/” then it will work…
Seems it’s blocking incoming packets for not matching plex.tv…
Developers, please fix this one.
Also, allow some option to remove dvr if something is wrong, don’t just “something wrong happened”, this does not help user to solve this…
