Can you read? I just explained that I know how to do to bring up the menu. The problem is that there is no thumbnails on the actors.
Have to agree with wahlman.j, I read it the same way he did, you never mentioned that you had plane images instead of the actual thumbnails, you just said you seemed to remember thumbnails and wahlman advised you where they were.
Now that you have shown you know how to get them and that they are blank all I can say is Mine still shows the thumbnails so it sounds like your PMS is not caching them.(or maybe an issue with them being transcoded to the correct size etc)
"I´m not sure but i think i remembered when i choose "More" and the list of actors it was a smal picture of them.
Now i don´t see that anymore."
Ok if someone want to misinterpret that sentence it's always possible.
As far as I know “The Movie Database” is the only agent that returns actor images. So if you only use freebase or another agent or “The Movie Database” isn’t the first agent in the list then I don’t think PMS will pull in actor images.
