Thumbnails Unable to be created
I am on server version 1.24.4.5081 as of this post.
I am unsure if this is a bug or not, but I am unable to generate preview thumbnails on the video scrubber. My install is mostly default, except for having made a symlink to use my USB 3.0 SSD for the Application Support data instead of the system drive (I am on an Rpi4 with an SD card and I want to minimize the amount of writing done to it, as well as conserve it’s space).
When I previously had my system using the SD card, I was able to generate the files. The Pi4 is absolutely strong enough (as is my old 3b+). I have done a clean install of PMS using the new symlink and I know that it is actually using it, and so that should have all the permissions set properly to it. Under the advanced tab on libraries, I do have the option to generate thumbnails enabled.
I have access to the logs, but I am unsure of which log to read. I assume it’s going to be “Plex Media Scanner Chapter Thumbnails1.log
In there, I see this: Oct 05, 2021 03:49:55.648 [0xb6cdedcc] ERROR - [MI] Unsupported codec ‘h264’ for file ‘"/media/plexmedia/Movies/Die Hard/Die Hard.mp4"’ as an example.
Can anyone help me?
Bump.
Anyone??
Hmm, that’s strange. I think the most recent log file will be without the 1 in it. So check out Plex Media Scanner Chapter Thumbnails.log below all the others. Upload the entire log here (drag and drop into the chat box), not just one line from it. While we’re at it, it might be good to save all the logs in case anyone asks for it. In case you don’t know, go to Settings > SERVERNAME > Manage > Troubleshooting and click Download logs.
Make sure to reproduce the attempt to generate a preview so that it shows up in the log. Add a new (fake named) file or something.
The log you looked at sounds like it is for generating Chapter thumbnail images, not regular video preview thumbnails. Which of the two did you mean? If the latter, it might be in another log (I’m looking at my logs, I don’t know which one it would be in).
I am looking for regular video preview thumbnails (the ones that popup with the scrubber).
Here is the log.
Oct 23, 2021 17:39:15.365 [0xb4035d50] INFO - Plex Media Scanner v1.24.4.5081-e362dc1ee - Raspbian GNU/Linux PC armv7l - build: linux-armv7neon - GMT 01:00
Oct 23, 2021 17:39:15.366 [0xb4035d50] INFO - Linux version: 10 (buster), language: en-US
Oct 23, 2021 17:39:15.366 [0xb4035d50] INFO - Processor Arm
Oct 23, 2021 17:39:15.366 [0xb4035d50] INFO - /usr/lib/plexmediaserver/Plex Media Scanner --analyze --manual --server-action index --item 78 --log-file-suffix  Analysis
Oct 23, 2021 17:39:15.368 [0xb6c7edcc] WARN - [FFMPEG] - Error loading external lib: Error loading shared library /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/be22e26-4019-linux-armv7neon/liblibx264_encoder.so: Operation not permitted
Oct 23, 2021 17:39:15.368 [0xb6c7edcc] WARN - [FFMPEG] - Error loading external lib: Error loading shared library /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/be22e26-4019-linux-armv7neon/libh264_decoder.so: Operation not permitted
Oct 23, 2021 17:39:15.369 [0xb6c7edcc] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.35.5, threadsafe=1
Oct 23, 2021 17:39:15.702 [0xb6c7edcc] DEBUG - Analyzing media parts for item 78 (Hocus Pocus): 78
Oct 23, 2021 17:39:15.706 [0xb6c7edcc] DEBUG - [ID 78] Media part analysis: /media/plexmedia/Movies/Hocus Pocus/Hocus Pocus.mp4
Oct 23, 2021 17:39:15.706 [0xb6c7edcc] DEBUG - [MI] Opening input file: "/media/plexmedia/Movies/Hocus Pocus/Hocus Pocus.mp4"
Oct 23, 2021 17:39:15.706 [0xb6c7edcc] DEBUG - [FFMPEG] - Opening '/media/plexmedia/Movies/Hocus Pocus/Hocus Pocus.mp4' for reading
Oct 23, 2021 17:39:15.706 [0xb6c7edcc] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto'
Oct 23, 2021 17:39:15.707 [0xb6c7edcc] DEBUG - [FFMPEG] - Format mov,mp4,m4a,3gp,3g2,mj2 probed with size=2048 and score=100
Oct 23, 2021 17:39:15.707 [0xb6c7edcc] DEBUG - [FFMPEG] - ISO: File Type Major Brand: isom
Oct 23, 2021 17:39:15.707 [0xb6c7edcc] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Oct 23, 2021 17:39:15.753 [0xb6c7edcc] DEBUG - [FFMPEG] - Setting codecpar->delay to 2 for stream st: 0
Oct 23, 2021 17:39:15.754 [0xb6c7edcc] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Oct 23, 2021 17:39:15.800 [0xb6c7edcc] DEBUG - [FFMPEG] - Before avformat_find_stream_info() pos: 1344389318 bytes read:3002944 seeks:1 nb_streams:2
Oct 23, 2021 17:39:15.801 [0xb6c7edcc] DEBUG - [FFMPEG] - All info found
Oct 23, 2021 17:39:15.801 [0xb6c7edcc] DEBUG - [FFMPEG] - After avformat_find_stream_info() pos: 2989549 bytes read:3035712 seeks:2 frames:13
Oct 23, 2021 17:39:15.801 [0xb6c7edcc] DEBUG - [MI] Opening "/media/plexmedia/Movies/Hocus Pocus/Hocus Pocus.mp4" for MP4 atom parsing
Oct 23, 2021 17:39:15.801 [0xb6c7edcc] DEBUG - Mp4AtomParser: Skipping ftyp atom of size 24 at offset 0
Oct 23, 2021 17:39:15.801 [0xb6c7edcc] DEBUG - Mp4AtomParser: Found moov atom of size 2987633 at offset 24
Oct 23, 2021 17:39:15.814 [0xb6c7edcc] DEBUG - Mp4AtomParser: Found trak atom of size 1706327 at offset 161
Oct 23, 2021 17:39:15.814 [0xb6c7edcc] DEBUG - Mp4AtomParser: Found trak atom of size 1281169 at offset 1706488
Oct 23, 2021 17:39:15.814 [0xb6c7edcc] DEBUG - Mp4AtomParser: Found mdia atom of size 1706227 at offset 261
Oct 23, 2021 17:39:15.814 [0xb6c7edcc] DEBUG - Mp4AtomParser: Found minf atom of size 1706154 at offset 334
Oct 23, 2021 17:39:15.814 [0xb6c7edcc] DEBUG - Mp4AtomParser: Found stbl atom of size 1706090 at offset 398
Oct 23, 2021 17:39:15.814 [0xb6c7edcc] DEBUG - Mp4AtomParser: Found mdia atom of size 1281069 at offset 1706588
Oct 23, 2021 17:39:15.814 [0xb6c7edcc] DEBUG - Mp4AtomParser: Found minf atom of size 1280974 at offset 1706683
Oct 23, 2021 17:39:15.814 [0xb6c7edcc] DEBUG - Mp4AtomParser: Found stbl atom of size 1280914 at offset 1706743
Oct 23, 2021 17:39:15.830 [0xb6c7edcc] DEBUG - [MI]  * c379b8ddc2edb43f902d1e3971badd8d65193f9e [mp4 h264/aac] Duration: 5768085ms, 1920x1040 (1.846154) 23.976fps, bitrate=1864kbps, audio channels=2, optimizedForStreaming=1 ("/media/plexmedia/Movies/Hocus Pocus/Hocus Pocus.mp4")
Oct 23, 2021 17:39:15.830 [0xb6c7edcc] DEBUG - [MI] Chapters had generic titles, clearing.
Oct 23, 2021 17:39:15.831 [0xb6c7edcc] DEBUG - [MI] Closing input file: "/media/plexmedia/Movies/Hocus Pocus/Hocus Pocus.mp4"
Oct 23, 2021 17:39:15.834 [0xb6c7edcc] DEBUG - Committing media stream changes for part 78
Oct 23, 2021 17:39:15.836 [0xb6c7edcc] DEBUG - Updating media item 78, size=1344389349, metadata_item_id=78
Oct 23, 2021 17:39:15.836 [0xb6c7edcc] DEBUG - Updating part with ID=78 [/media/plexmedia/Movies/Hocus Pocus/Hocus Pocus.mp4]
Oct 23, 2021 17:39:15.837 [0xb3510d50] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=1&metadataItemID=78&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=analyzing
Oct 23, 2021 17:39:15.839 [0xb3510d50] DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=1&metadataItemID=78&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=analyzing
Oct 23, 2021 17:39:15.839 [0xb6c7edcc] DEBUG - [MI] Opening input file: "/media/plexmedia/Movies/Hocus Pocus/Hocus Pocus.mp4"
Oct 23, 2021 17:39:15.839 [0xb6c7edcc] DEBUG - [FFMPEG] - Opening '/media/plexmedia/Movies/Hocus Pocus/Hocus Pocus.mp4' for reading
Oct 23, 2021 17:39:15.839 [0xb6c7edcc] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto'
Oct 23, 2021 17:39:15.839 [0xb3510d50] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=1&metadataItemID=78&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=thumbnailing
Oct 23, 2021 17:39:15.839 [0xb6c7edcc] DEBUG - [FFMPEG] - Format mov,mp4,m4a,3gp,3g2,mj2 probed with size=2048 and score=100
Oct 23, 2021 17:39:15.840 [0xb6c7edcc] DEBUG - [FFMPEG] - ISO: File Type Major Brand: isom
Oct 23, 2021 17:39:15.840 [0xb6c7edcc] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Oct 23, 2021 17:39:15.841 [0xb3510d50] DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=1&metadataItemID=78&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=thumbnailing (reused)
Oct 23, 2021 17:39:15.928 [0xb6c7edcc] DEBUG - [FFMPEG] - Setting codecpar->delay to 2 for stream st: 0
Oct 23, 2021 17:39:15.929 [0xb6c7edcc] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Oct 23, 2021 17:39:15.978 [0xb6c7edcc] DEBUG - [FFMPEG] - Before avformat_find_stream_info() pos: 1344389318 bytes read:3002944 seeks:1 nb_streams:2
Oct 23, 2021 17:39:15.978 [0xb6c7edcc] DEBUG - [FFMPEG] - All info found
Oct 23, 2021 17:39:15.979 [0xb6c7edcc] DEBUG - [FFMPEG] - After avformat_find_stream_info() pos: 2989549 bytes read:3035712 seeks:2 frames:13
Oct 23, 2021 17:39:15.979 [0xb6c7edcc] DEBUG - Creating /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Media/localhost/c/379b8ddc2edb43f902d1e3971badd8d65193f9e.bundle/Contents/Thumbnails/thumb1.jpg (50.0%, 720x512).
Oct 23, 2021 17:39:15.979 [0xb6c7edcc] ERROR - [MI] Unsupported codec 'h264' for file '"/media/plexmedia/Movies/Hocus Pocus/Hocus Pocus.mp4"'
Oct 23, 2021 17:39:15.979 [0xb6c7edcc] DEBUG - [MI] Closing input file: "/media/plexmedia/Movies/Hocus Pocus/Hocus Pocus.mp4"
Oct 23, 2021 17:39:15.981 [0xb6c7edcc] DEBUG - [MI] Opening input file: "/media/plexmedia/Movies/Hocus Pocus/Hocus Pocus.mp4"
Oct 23, 2021 17:39:15.981 [0xb6c7edcc] DEBUG - [FFMPEG] - Opening '/media/plexmedia/Movies/Hocus Pocus/Hocus Pocus.mp4' for reading
Oct 23, 2021 17:39:15.981 [0xb6c7edcc] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto'
Oct 23, 2021 17:39:15.982 [0xb6c7edcc] DEBUG - [FFMPEG] - Format mov,mp4,m4a,3gp,3g2,mj2 probed with size=2048 and score=100
Oct 23, 2021 17:39:15.982 [0xb6c7edcc] DEBUG - [FFMPEG] - ISO: File Type Major Brand: isom
Oct 23, 2021 17:39:15.982 [0xb6c7edcc] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Oct 23, 2021 17:39:16.030 [0xb6c7edcc] DEBUG - [FFMPEG] - Setting codecpar->delay to 2 for stream st: 0
Oct 23, 2021 17:39:16.030 [0xb6c7edcc] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Oct 23, 2021 17:39:16.077 [0xb6c7edcc] DEBUG - [FFMPEG] - Before avformat_find_stream_info() pos: 1344389318 bytes read:3002944 seeks:1 nb_streams:2
Oct 23, 2021 17:39:16.078 [0xb6c7edcc] DEBUG - [FFMPEG] - All info found
Oct 23, 2021 17:39:16.078 [0xb6c7edcc] DEBUG - [FFMPEG] - After avformat_find_stream_info() pos: 2989549 bytes read:3035712 seeks:2 frames:13
Oct 23, 2021 17:39:16.078 [0xb6c7edcc] DEBUG - Creating /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Media/localhost/c/379b8ddc2edb43f902d1e3971badd8d65193f9e.bundle/Contents/Art/art1.jpg (50.0%, 1280x720).
Oct 23, 2021 17:39:16.079 [0xb6c7edcc] ERROR - [MI] Unsupported codec 'h264' for file '"/media/plexmedia/Movies/Hocus Pocus/Hocus Pocus.mp4"'
Oct 23, 2021 17:39:16.079 [0xb6c7edcc] DEBUG - [MI] Closing input file: "/media/plexmedia/Movies/Hocus Pocus/Hocus Pocus.mp4"
Oct 23, 2021 17:39:16.083 [0xb6c7edcc] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Oct 23, 2021 17:39:16.083 [0xb6c7edcc] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/changestamp
Oct 23, 2021 17:39:16.085 [0xb6c7edcc] DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/library/changestamp (reused)
Oct 23, 2021 17:39:16.085 [0xb6c7edcc] DEBUG - Updating metadata item (save) (Hocus Pocus) with ID 78
Oct 23, 2021 17:39:16.089 [0xb3510d50] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=1&metadataItemID=78&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=idle
Oct 23, 2021 17:39:16.091 [0xb3510d50] DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=1&metadataItemID=78&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=idle (reused)
Oct 23, 2021 17:39:16.125 [0xb6c7edcc] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Oct 23, 2021 17:39:16.125 [0xb6c7edcc] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/changestamp
Oct 23, 2021 17:39:16.127 [0xb6c7edcc] DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/library/changestamp (reused)
Oct 23, 2021 17:39:16.127 [0xb6c7edcc] DEBUG - Updating metadata item (save) (Hocus Pocus) with ID 78
Oct 23, 2021 17:39:16.131 [0xb6c7edcc] DEBUG - HTTP requesting PUT http://127.0.0.1:32400/library/metadata/78/index?force=0
Oct 23, 2021 17:39:16.146 [0xb6c7edcc] DEBUG - HTTP/1.1 (0.0s) 200 response from PUT http://127.0.0.1:32400/library/metadata/78/index?force=0 (reused)
Is /var/lib/plexmediaserver/Library and that which is below it mounted on a non-root partition?
will occur if the shared library load is attempted from a partition without the exec permission bit having been set at mount time in /etc/fstab
Yes. It’s on an SSD via USB at /media/plexmedia
I checked fstab and did not see exec set, so I added it and I am rebooting now and will test.
Plex Media Scanner Analysis.log
Oct 23, 2021 21:16:10.838 [0xb4061d50] INFO - Plex Media Scanner v1.24.4.5081-e362dc1ee - Raspbian GNU/Linux PC armv7l - build: linux-armv7neon - GMT -04:00
Oct 23, 2021 21:16:10.838 [0xb4061d50] INFO - Linux version: 10 (buster), language: en-US
Oct 23, 2021 21:16:10.839 [0xb4061d50] INFO - Processor Arm
Oct 23, 2021 21:16:10.839 [0xb4061d50] INFO - /usr/lib/plexmediaserver/Plex Media Scanner --analyze --manual --server-action index --item 5 --log-file-suffix  Analysis
Oct 23, 2021 21:16:10.842 [0xb6caadcc] WARN - [FFMPEG] - Error loading external lib: Error loading shared library /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/be22e26-4019-linux-armv7neon/liblibx264_encoder.so: Operation not permitted
Oct 23, 2021 21:16:10.842 [0xb6caadcc] WARN - [FFMPEG] - Error loading external lib: Error loading shared library /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/be22e26-4019-linux-armv7neon/libh264_decoder.so: Operation not permitted
Oct 23, 2021 21:16:10.842 [0xb6caadcc] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.35.5, threadsafe=1
Oct 23, 2021 21:16:11.161 [0xb6caadcc] DEBUG - Analyzing media parts for item 5 (Ace Ventura: Pet Detective): 5
Oct 23, 2021 21:16:11.167 [0xb6caadcc] DEBUG - [ID 5] Media part analysis: /media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4
Oct 23, 2021 21:16:11.167 [0xb6caadcc] DEBUG - [MI] Opening input file: "/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4"
Oct 23, 2021 21:16:11.167 [0xb6caadcc] DEBUG - [FFMPEG] - Opening '/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4' for reading
Oct 23, 2021 21:16:11.167 [0xb6caadcc] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto'
Oct 23, 2021 21:16:11.168 [0xb6caadcc] DEBUG - [FFMPEG] - Format mov,mp4,m4a,3gp,3g2,mj2 probed with size=2048 and score=100
Oct 23, 2021 21:16:11.169 [0xb6caadcc] DEBUG - [FFMPEG] - ISO: File Type Major Brand: isom
Oct 23, 2021 21:16:11.169 [0xb6caadcc] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Oct 23, 2021 21:16:11.271 [0xb6caadcc] DEBUG - [FFMPEG] - Setting codecpar->delay to 2 for stream st: 0
Oct 23, 2021 21:16:11.271 [0xb6caadcc] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Oct 23, 2021 21:16:11.322 [0xb6caadcc] WARN - [FFMPEG] - stream 0, timescale not set
Oct 23, 2021 21:16:11.322 [0xb6caadcc] DEBUG - [FFMPEG] - Before avformat_find_stream_info() pos: 1322269334 bytes read:2785702 seeks:2 nb_streams:3
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=d8 avail_size_in_buf=53668
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 0 bytes (0 bits)
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=e0 avail_size_in_buf=53666
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 16 bytes (128 bits)
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=db avail_size_in_buf=53648
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - index=0
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - qscale[0]: 2
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 67 bytes (536 bits)
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=db avail_size_in_buf=53579
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - index=1
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - qscale[1]: 5
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c2 avail_size_in_buf=53510
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - Changing bps from 0 to 8
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - sof0: picture: 518x800
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - component 0 2:2 id: 0 quant:0
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - component 1 1:1 id: 1 quant:1
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - component 2 1:1 id: 2 quant:1
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - pix fmt id 22111100
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - Format yuvj420p chosen by get_format().
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 17 bytes (136 bits)
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=53491
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=53462
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 48504 bytes
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=53436
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 4932 bytes (39456 bits)
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=48501
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 44120 bytes
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=48453
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 4333 bytes (34664 bits)
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=44110
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 43226 bytes
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=44069
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 843 bytes (6744 bits)
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=43223
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 42346 bytes
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=43183
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 837 bytes (6696 bits)
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=42340
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 39441 bytes
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=42287
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 2846 bytes (22768 bits)
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=39432
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 29474 bytes
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=39390
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 9916 bytes (79328 bits)
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 28179 bytes
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=29430
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 1251 bytes (10008 bits)
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=28173
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 27305 bytes
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=28135
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 830 bytes (6640 bits)
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=27302
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 26420 bytes
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=27265
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 845 bytes (6760 bits)
Oct 23, 2021 21:16:11.335 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=26416
Oct 23, 2021 21:16:11.336 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 82 bytes
Oct 23, 2021 21:16:11.336 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=26376
Oct 23, 2021 21:16:11.336 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 26294 bytes (210352 bits)
Oct 23, 2021 21:16:11.336 [0xb6caadcc] DEBUG - [FFMPEG] - marker=d9 avail_size_in_buf=0
Oct 23, 2021 21:16:11.336 [0xb6caadcc] DEBUG - [FFMPEG] - decode frame unused 0 bytes
Oct 23, 2021 21:16:11.337 [0xb6caadcc] DEBUG - [FFMPEG] - All info found
Oct 23, 2021 21:16:11.337 [0xb6caadcc] DEBUG - [FFMPEG] - After avformat_find_stream_info() pos: 3593697 bytes read:2818470 seeks:3 frames:14
Oct 23, 2021 21:16:11.337 [0xb6caadcc] DEBUG - [MI] Opening "/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4" for MP4 atom parsing
Oct 23, 2021 21:16:11.337 [0xb6caadcc] DEBUG - Mp4AtomParser: Skipping ftyp atom of size 24 at offset 0
Oct 23, 2021 21:16:11.337 [0xb6caadcc] DEBUG - Mp4AtomParser: Found moov atom of size 2724187 at offset 24
Oct 23, 2021 21:16:11.349 [0xb6caadcc] DEBUG - Mp4AtomParser: Found trak atom of size 1519917 at offset 161
Oct 23, 2021 21:16:11.349 [0xb6caadcc] DEBUG - Mp4AtomParser: Found trak atom of size 1146281 at offset 1520078
Oct 23, 2021 21:16:11.349 [0xb6caadcc] DEBUG - Mp4AtomParser: Found mdia atom of size 1519817 at offset 261
Oct 23, 2021 21:16:11.349 [0xb6caadcc] DEBUG - Mp4AtomParser: Found minf atom of size 1519683 at offset 395
Oct 23, 2021 21:16:11.349 [0xb6caadcc] DEBUG - Mp4AtomParser: Found stbl atom of size 1519619 at offset 459
Oct 23, 2021 21:16:11.349 [0xb6caadcc] DEBUG - Mp4AtomParser: Found mdia atom of size 1146181 at offset 1520178
Oct 23, 2021 21:16:11.349 [0xb6caadcc] DEBUG - Mp4AtomParser: Found minf atom of size 1146086 at offset 1520273
Oct 23, 2021 21:16:11.349 [0xb6caadcc] DEBUG - Mp4AtomParser: Found stbl atom of size 1146026 at offset 1520333
Oct 23, 2021 21:16:11.368 [0xb6caadcc] DEBUG - [MI]  * 002939fe9fb38cc27f96a6465a9484b0b5b3ff93 [mp4 h264/aac] Duration: 5160640ms, 1920x1080 (1.777778) 23.976fps, bitrate=2049kbps, audio channels=2, optimizedForStreaming=1 ("/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4")
Oct 23, 2021 21:16:11.368 [0xb6caadcc] DEBUG - [MI] Chapters had generic titles, clearing.
Oct 23, 2021 21:16:11.370 [0xb6caadcc] DEBUG - [MI] Closing input file: "/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4"
Oct 23, 2021 21:16:11.374 [0xb6caadcc] DEBUG - Updating media item 5, size=1322269361, metadata_item_id=5
Oct 23, 2021 21:16:11.374 [0xb6caadcc] DEBUG - Updating part with ID=5 [/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4]
Oct 23, 2021 21:16:11.375 [0xb353cd50] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=1&metadataItemID=5&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=analyzing
Oct 23, 2021 21:16:11.378 [0xb6caadcc] DEBUG - [MI] Opening input file: "/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4"
Oct 23, 2021 21:16:11.378 [0xb6caadcc] DEBUG - [FFMPEG] - Opening '/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4' for reading
Oct 23, 2021 21:16:11.378 [0xb6caadcc] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto'
Oct 23, 2021 21:16:11.379 [0xb6caadcc] DEBUG - [FFMPEG] - Format mov,mp4,m4a,3gp,3g2,mj2 probed with size=2048 and score=100
Oct 23, 2021 21:16:11.379 [0xb6caadcc] DEBUG - [FFMPEG] - ISO: File Type Major Brand: isom
Oct 23, 2021 21:16:11.379 [0xb6caadcc] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Oct 23, 2021 21:16:11.380 [0xb353cd50] DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=1&metadataItemID=5&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=analyzing
Oct 23, 2021 21:16:11.383 [0xb353cd50] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=1&metadataItemID=5&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=thumbnailing
Oct 23, 2021 21:16:11.386 [0xb353cd50] DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=1&metadataItemID=5&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=thumbnailing (reused)
Oct 23, 2021 21:16:11.421 [0xb6caadcc] DEBUG - [FFMPEG] - Setting codecpar->delay to 2 for stream st: 0
Oct 23, 2021 21:16:11.421 [0xb6caadcc] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Oct 23, 2021 21:16:11.465 [0xb6caadcc] WARN - [FFMPEG] - stream 0, timescale not set
Oct 23, 2021 21:16:11.465 [0xb6caadcc] DEBUG - [FFMPEG] - Before avformat_find_stream_info() pos: 1322269334 bytes read:2785702 seeks:2 nb_streams:3
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=d8 avail_size_in_buf=53668
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 0 bytes (0 bits)
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=e0 avail_size_in_buf=53666
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 16 bytes (128 bits)
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=db avail_size_in_buf=53648
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - index=0
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - qscale[0]: 2
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 67 bytes (536 bits)
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=db avail_size_in_buf=53579
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - index=1
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - qscale[1]: 5
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c2 avail_size_in_buf=53510
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - Changing bps from 0 to 8
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - sof0: picture: 518x800
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - component 0 2:2 id: 0 quant:0
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - component 1 1:1 id: 1 quant:1
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - component 2 1:1 id: 2 quant:1
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - pix fmt id 22111100
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - Format yuvj420p chosen by get_format().
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 17 bytes (136 bits)
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=53491
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=53462
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 48504 bytes
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=53436
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 4932 bytes (39456 bits)
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=48501
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 44120 bytes
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=48453
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 4333 bytes (34664 bits)
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=44110
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 43226 bytes
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=44069
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 843 bytes (6744 bits)
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=43223
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 42346 bytes
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=43183
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 837 bytes (6696 bits)
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=42340
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 39441 bytes
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=42287
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 2846 bytes (22768 bits)
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=39432
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 29474 bytes
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=39390
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 9916 bytes (79328 bits)
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 28179 bytes
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=29430
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 1251 bytes (10008 bits)
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=28173
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 27305 bytes
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=28135
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 830 bytes (6640 bits)
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=27302
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 26420 bytes
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=27265
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 845 bytes (6760 bits)
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=26416
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 82 bytes
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=26376
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 26294 bytes (210352 bits)
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - marker=d9 avail_size_in_buf=0
Oct 23, 2021 21:16:11.466 [0xb6caadcc] DEBUG - [FFMPEG] - decode frame unused 0 bytes
Oct 23, 2021 21:16:11.467 [0xb6caadcc] DEBUG - [FFMPEG] - All info found
Oct 23, 2021 21:16:11.467 [0xb6caadcc] DEBUG - [FFMPEG] - After avformat_find_stream_info() pos: 3593697 bytes read:2818470 seeks:3 frames:14
Oct 23, 2021 21:16:11.467 [0xb6caadcc] DEBUG - Creating /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Media/localhost/0/02939fe9fb38cc27f96a6465a9484b0b5b3ff93.bundle/Contents/Thumbnails/thumb1.jpg (50.0%, 720x512).
Oct 23, 2021 21:16:11.467 [0xb6caadcc] ERROR - [MI] Unsupported codec 'h264' for file '"/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4"'
Oct 23, 2021 21:16:11.467 [0xb6caadcc] DEBUG - [MI] Closing input file: "/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4"
Oct 23, 2021 21:16:11.469 [0xb6caadcc] DEBUG - [MI] Opening input file: "/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4"
Oct 23, 2021 21:16:11.470 [0xb6caadcc] DEBUG - [FFMPEG] - Opening '/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4' for reading
Oct 23, 2021 21:16:11.470 [0xb6caadcc] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto'
Oct 23, 2021 21:16:11.470 [0xb6caadcc] DEBUG - [FFMPEG] - Format mov,mp4,m4a,3gp,3g2,mj2 probed with size=2048 and score=100
Oct 23, 2021 21:16:11.471 [0xb6caadcc] DEBUG - [FFMPEG] - ISO: File Type Major Brand: isom
Oct 23, 2021 21:16:11.471 [0xb6caadcc] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Oct 23, 2021 21:16:11.514 [0xb6caadcc] DEBUG - [FFMPEG] - Setting codecpar->delay to 2 for stream st: 0
Oct 23, 2021 21:16:11.515 [0xb6caadcc] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Oct 23, 2021 21:16:11.558 [0xb6caadcc] WARN - [FFMPEG] - stream 0, timescale not set
Oct 23, 2021 21:16:11.558 [0xb6caadcc] DEBUG - [FFMPEG] - Before avformat_find_stream_info() pos: 1322269334 bytes read:2785702 seeks:2 nb_streams:3
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=d8 avail_size_in_buf=53668
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 0 bytes (0 bits)
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=e0 avail_size_in_buf=53666
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 16 bytes (128 bits)
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=db avail_size_in_buf=53648
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - index=0
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - qscale[0]: 2
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 67 bytes (536 bits)
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=db avail_size_in_buf=53579
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - index=1
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - qscale[1]: 5
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c2 avail_size_in_buf=53510
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - Changing bps from 0 to 8
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - sof0: picture: 518x800
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - component 0 2:2 id: 0 quant:0
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - component 1 1:1 id: 1 quant:1
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - component 2 1:1 id: 2 quant:1
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - pix fmt id 22111100
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - Format yuvj420p chosen by get_format().
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 17 bytes (136 bits)
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=53491
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=53462
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 48504 bytes
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=53436
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 4932 bytes (39456 bits)
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=48501
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 44120 bytes
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=48453
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 4333 bytes (34664 bits)
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=44110
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 43226 bytes
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=44069
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 843 bytes (6744 bits)
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=43223
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 42346 bytes
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=43183
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 837 bytes (6696 bits)
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=42340
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 39441 bytes
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=42287
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 2846 bytes (22768 bits)
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=39432
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 29474 bytes
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=39390
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 9916 bytes (79328 bits)
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 28179 bytes
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=29430
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 1251 bytes (10008 bits)
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=28173
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 27305 bytes
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=28135
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 830 bytes (6640 bits)
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=27302
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 26420 bytes
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=27265
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 845 bytes (6760 bits)
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=26416
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - escaping removed 82 bytes
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=26376
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker parser used 26294 bytes (210352 bits)
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - marker=d9 avail_size_in_buf=0
Oct 23, 2021 21:16:11.559 [0xb6caadcc] DEBUG - [FFMPEG] - decode frame unused 0 bytes
Oct 23, 2021 21:16:11.560 [0xb6caadcc] DEBUG - [FFMPEG] - All info found
Oct 23, 2021 21:16:11.560 [0xb6caadcc] DEBUG - [FFMPEG] - After avformat_find_stream_info() pos: 3593697 bytes read:2818470 seeks:3 frames:14
Oct 23, 2021 21:16:11.560 [0xb6caadcc] DEBUG - Creating /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Media/localhost/0/02939fe9fb38cc27f96a6465a9484b0b5b3ff93.bundle/Contents/Art/art1.jpg (50.0%, 1280x720).
Oct 23, 2021 21:16:11.560 [0xb6caadcc] ERROR - [MI] Unsupported codec 'h264' for file '"/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4"'
Oct 23, 2021 21:16:11.560 [0xb6caadcc] DEBUG - [MI] Closing input file: "/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4"
Oct 23, 2021 21:16:11.564 [0xb6caadcc] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Oct 23, 2021 21:16:11.565 [0xb6caadcc] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/changestamp
Oct 23, 2021 21:16:11.567 [0xb6caadcc] DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/library/changestamp (reused)
Oct 23, 2021 21:16:11.567 [0xb6caadcc] DEBUG - Updating metadata item (save) (Ace Ventura: Pet Detective) with ID 5
Oct 23, 2021 21:16:11.573 [0xb353cd50] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=1&metadataItemID=5&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=idle
Oct 23, 2021 21:16:11.575 [0xb353cd50] DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=1&metadataItemID=5&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=idle (reused)
Oct 23, 2021 21:16:11.614 [0xb6caadcc] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Oct 23, 2021 21:16:11.614 [0xb6caadcc] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/changestamp
Oct 23, 2021 21:16:11.616 [0xb6caadcc] DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/library/changestamp (reused)
Oct 23, 2021 21:16:11.616 [0xb6caadcc] DEBUG - Updating metadata item (save) (Ace Ventura: Pet Detective) with ID 5
Oct 23, 2021 21:16:11.621 [0xb6caadcc] DEBUG - HTTP requesting PUT http://127.0.0.1:32400/library/metadata/5/index?force=0
Oct 23, 2021 21:16:11.641 [0xb6caadcc] DEBUG - HTTP/1.1 (0.0s) 200 response from PUT http://127.0.0.1:32400/library/metadata/5/index?force=0 (reused)
MODERATOR EDIT: Added </> Code formatting for legibility
Looking a whole lot better. I don’t see any “Operation not permitted”.
Now it looks like the codecs might need to be redownloaded
-or-
that is a XviD file?
How do I redownload them?
In /media/plexmedia/PMSAppSupport/Plex Media Server/Codecs/be22e26-4019-linux-armv7neon, I see the following:
libh264_decoder.so
These are h264 mp4 videos with 2.0ch aac audio.
  1. Stop Plex
  2. Delete the .so files . Do not delete the .*_id file (your license)
  3. Start Plex
  4. Play anything needing the codec. It will download on demand (a few extra seconds to download fresh)
Okay, tried that. Still not working. I saw that it downloaded the decoder codec but it still says “Unsupported codec” for any video that I try. I ran the files through handbrake and confirmed the files have h264 videos in the mp4 container so this should work. Here is the latest log:
Oct 24, 2021 01:02:16.585 [0xb3fe7d50] INFO - Plex Media Scanner v1.24.4.5081-e362dc1ee - Raspbian GNU/Linux PC armv7l - build: linux-armv7neon - GMT -04:00
Oct 24, 2021 01:02:16.586 [0xb3fe7d50] INFO - Linux version: 10 (buster), language: en-US
Oct 24, 2021 01:02:16.586 [0xb3fe7d50] INFO - Processor Arm
Oct 24, 2021 01:02:16.586 [0xb3fe7d50] INFO - /usr/lib/plexmediaserver/Plex Media Scanner --analyze --manual --server-action index --item 5 --log-file-suffix  Analysis
Oct 24, 2021 01:02:16.588 [0xb6c30dcc] WARN - [FFMPEG] - Error loading external lib: Error loading shared library /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/be22e26-4019-linux-armv7neon/libh264_decoder.so: Operation not permitted
Oct 24, 2021 01:02:16.589 [0xb6c30dcc] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.35.5, threadsafe=1
Oct 24, 2021 01:02:16.941 [0xb6c30dcc] DEBUG - Analyzing media parts for item 5 (Ace Ventura: Pet Detective): 5
Oct 24, 2021 01:02:16.943 [0xb6c30dcc] DEBUG - [ID 5] Media part analysis: /media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4
Oct 24, 2021 01:02:16.943 [0xb6c30dcc] DEBUG - [MI] Opening input file: "/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4"
Oct 24, 2021 01:02:16.943 [0xb6c30dcc] DEBUG - [FFMPEG] - Opening '/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4' for reading
Oct 24, 2021 01:02:16.943 [0xb6c30dcc] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto'
Oct 24, 2021 01:02:16.944 [0xb6c30dcc] DEBUG - [FFMPEG] - Format mov,mp4,m4a,3gp,3g2,mj2 probed with size=2048 and score=100
Oct 24, 2021 01:02:16.944 [0xb6c30dcc] DEBUG - [FFMPEG] - ISO: File Type Major Brand: isom
Oct 24, 2021 01:02:16.945 [0xb6c30dcc] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Oct 24, 2021 01:02:16.990 [0xb6c30dcc] DEBUG - [FFMPEG] - Setting codecpar->delay to 2 for stream st: 0
Oct 24, 2021 01:02:16.990 [0xb6c30dcc] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Oct 24, 2021 01:02:17.035 [0xb6c30dcc] WARN - [FFMPEG] - stream 0, timescale not set
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - Before avformat_find_stream_info() pos: 1322269334 bytes read:2785702 seeks:2 nb_streams:3
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=d8 avail_size_in_buf=53668
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 0 bytes (0 bits)
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=e0 avail_size_in_buf=53666
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 16 bytes (128 bits)
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=db avail_size_in_buf=53648
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - index=0
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - qscale[0]: 2
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 67 bytes (536 bits)
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=db avail_size_in_buf=53579
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - index=1
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - qscale[1]: 5
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c2 avail_size_in_buf=53510
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - Changing bps from 0 to 8
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - sof0: picture: 518x800
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - component 0 2:2 id: 0 quant:0
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - component 1 1:1 id: 1 quant:1
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - component 2 1:1 id: 2 quant:1
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - pix fmt id 22111100
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - Format yuvj420p chosen by get_format().
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 17 bytes (136 bits)
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=53491
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=53462
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 48504 bytes
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=53436
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 4932 bytes (39456 bits)
Oct 24, 2021 01:02:17.036 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=48501
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 44120 bytes
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=48453
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 4333 bytes (34664 bits)
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=44110
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 0 bytes (0 bits)
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 43226 bytes
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=44069
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 843 bytes (6744 bits)
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=43223
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 42346 bytes
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=43183
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 837 bytes (6696 bits)
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=42340
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 39441 bytes
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=42287
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 2846 bytes (22768 bits)
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=39432
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 29474 bytes
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=39390
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 9916 bytes (79328 bits)
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 28179 bytes
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=29430
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 1251 bytes (10008 bits)
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=28173
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 27305 bytes
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=28135
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 830 bytes (6640 bits)
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=27302
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 26420 bytes
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=27265
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 845 bytes (6760 bits)
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=26416
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 82 bytes
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=26376
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 26294 bytes (210352 bits)
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=d9 avail_size_in_buf=0
Oct 24, 2021 01:02:17.037 [0xb6c30dcc] DEBUG - [FFMPEG] - decode frame unused 0 bytes
Oct 24, 2021 01:02:17.038 [0xb6c30dcc] DEBUG - [FFMPEG] - All info found
Oct 24, 2021 01:02:17.038 [0xb6c30dcc] DEBUG - [FFMPEG] - After avformat_find_stream_info() pos: 3593697 bytes read:2818470 seeks:3 frames:14
Oct 24, 2021 01:02:17.038 [0xb6c30dcc] DEBUG - [MI] Opening "/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4" for MP4 atom parsing
Oct 24, 2021 01:02:17.038 [0xb6c30dcc] DEBUG - Mp4AtomParser: Skipping ftyp atom of size 24 at offset 0
Oct 24, 2021 01:02:17.038 [0xb6c30dcc] DEBUG - Mp4AtomParser: Found moov atom of size 2724187 at offset 24
Oct 24, 2021 01:02:17.052 [0xb6c30dcc] DEBUG - Mp4AtomParser: Found trak atom of size 1519917 at offset 161
Oct 24, 2021 01:02:17.052 [0xb6c30dcc] DEBUG - Mp4AtomParser: Found trak atom of size 1146281 at offset 1520078
Oct 24, 2021 01:02:17.052 [0xb6c30dcc] DEBUG - Mp4AtomParser: Found mdia atom of size 1519817 at offset 261
Oct 24, 2021 01:02:17.052 [0xb6c30dcc] DEBUG - Mp4AtomParser: Found minf atom of size 1519683 at offset 395
Oct 24, 2021 01:02:17.052 [0xb6c30dcc] DEBUG - Mp4AtomParser: Found stbl atom of size 1519619 at offset 459
Oct 24, 2021 01:02:17.052 [0xb6c30dcc] DEBUG - Mp4AtomParser: Found mdia atom of size 1146181 at offset 1520178
Oct 24, 2021 01:02:17.052 [0xb6c30dcc] DEBUG - Mp4AtomParser: Found minf atom of size 1146086 at offset 1520273
Oct 24, 2021 01:02:17.052 [0xb6c30dcc] DEBUG - Mp4AtomParser: Found stbl atom of size 1146026 at offset 1520333
Oct 24, 2021 01:02:17.069 [0xb6c30dcc] DEBUG - [MI]  * 002939fe9fb38cc27f96a6465a9484b0b5b3ff93 [mp4 h264/aac] Duration: 5160640ms, 1920x1080 (1.777778) 23.976fps, bitrate=2049kbps, audio channels=2, optimizedForStreaming=1 ("/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4")
Oct 24, 2021 01:02:17.069 [0xb6c30dcc] DEBUG - [MI] Chapters had generic titles, clearing.
Oct 24, 2021 01:02:17.070 [0xb6c30dcc] DEBUG - [MI] Closing input file: "/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4"
Oct 24, 2021 01:02:17.073 [0xb6c30dcc] DEBUG - Updating media item 5, size=1322269361, metadata_item_id=5
Oct 24, 2021 01:02:17.074 [0xb6c30dcc] DEBUG - Updating part with ID=5 [/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4]
Oct 24, 2021 01:02:17.075 [0xb34c2d50] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=1&metadataItemID=5&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=analyzing
Oct 24, 2021 01:02:17.076 [0xb6c30dcc] DEBUG - [MI] Opening input file: "/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4"
Oct 24, 2021 01:02:17.076 [0xb6c30dcc] DEBUG - [FFMPEG] - Opening '/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4' for reading
Oct 24, 2021 01:02:17.076 [0xb6c30dcc] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto'
Oct 24, 2021 01:02:17.077 [0xb6c30dcc] DEBUG - [FFMPEG] - Format mov,mp4,m4a,3gp,3g2,mj2 probed with size=2048 and score=100
Oct 24, 2021 01:02:17.077 [0xb6c30dcc] DEBUG - [FFMPEG] - ISO: File Type Major Brand: isom
Oct 24, 2021 01:02:17.077 [0xb34c2d50] DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=1&metadataItemID=5&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=analyzing
Oct 24, 2021 01:02:17.077 [0xb6c30dcc] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Oct 24, 2021 01:02:17.077 [0xb34c2d50] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=1&metadataItemID=5&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=thumbnailing
Oct 24, 2021 01:02:17.079 [0xb34c2d50] DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=1&metadataItemID=5&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=thumbnailing (reused)
Oct 24, 2021 01:02:17.126 [0xb6c30dcc] DEBUG - [FFMPEG] - Setting codecpar->delay to 2 for stream st: 0
Oct 24, 2021 01:02:17.126 [0xb6c30dcc] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Oct 24, 2021 01:02:17.168 [0xb6c30dcc] WARN - [FFMPEG] - stream 0, timescale not set
Oct 24, 2021 01:02:17.168 [0xb6c30dcc] DEBUG - [FFMPEG] - Before avformat_find_stream_info() pos: 1322269334 bytes read:2785702 seeks:2 nb_streams:3
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=d8 avail_size_in_buf=53668
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 0 bytes (0 bits)
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=e0 avail_size_in_buf=53666
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 16 bytes (128 bits)
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=db avail_size_in_buf=53648
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - index=0
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - qscale[0]: 2
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 67 bytes (536 bits)
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=db avail_size_in_buf=53579
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - index=1
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - qscale[1]: 5
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c2 avail_size_in_buf=53510
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - Changing bps from 0 to 8
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - sof0: picture: 518x800
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - component 0 2:2 id: 0 quant:0
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - component 1 1:1 id: 1 quant:1
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - component 2 1:1 id: 2 quant:1
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - pix fmt id 22111100
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - Format yuvj420p chosen by get_format().
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 17 bytes (136 bits)
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=53491
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=53462
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 48504 bytes
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=53436
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 4932 bytes (39456 bits)
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=48501
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 44120 bytes
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=48453
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 4333 bytes (34664 bits)
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=44110
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 43226 bytes
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=44069
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 843 bytes (6744 bits)
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=43223
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 42346 bytes
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=43183
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 837 bytes (6696 bits)
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=42340
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 39441 bytes
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=42287
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 2846 bytes (22768 bits)
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=39432
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 29474 bytes
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=39390
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 9916 bytes (79328 bits)
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 28179 bytes
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=29430
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 1251 bytes (10008 bits)
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=28173
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 27305 bytes
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=28135
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 830 bytes (6640 bits)
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=27302
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 26420 bytes
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=27265
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 845 bytes (6760 bits)
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=26416
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 82 bytes
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=26376
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 26294 bytes (210352 bits)
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=d9 avail_size_in_buf=0
Oct 24, 2021 01:02:17.169 [0xb6c30dcc] DEBUG - [FFMPEG] - decode frame unused 0 bytes
Oct 24, 2021 01:02:17.170 [0xb6c30dcc] DEBUG - [FFMPEG] - All info found
Oct 24, 2021 01:02:17.170 [0xb6c30dcc] DEBUG - [FFMPEG] - After avformat_find_stream_info() pos: 3593697 bytes read:2818470 seeks:3 frames:14
Oct 24, 2021 01:02:17.170 [0xb6c30dcc] DEBUG - Creating /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Media/localhost/0/02939fe9fb38cc27f96a6465a9484b0b5b3ff93.bundle/Contents/Thumbnails/thumb1.jpg (50.0%, 720x512).
Oct 24, 2021 01:02:17.170 [0xb6c30dcc] ERROR - [MI] Unsupported codec 'h264' for file '"/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4"'
Oct 24, 2021 01:02:17.171 [0xb6c30dcc] ERROR - [MI] Unsupported codec 'h264' for file '"/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4"'
Oct 24, 2021 01:02:17.171 [0xb6c30dcc] DEBUG - [MI] Closing input file: "/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4"
Oct 24, 2021 01:02:17.172 [0xb6c30dcc] DEBUG - [MI] Opening input file: "/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4"
Oct 24, 2021 01:02:17.172 [0xb6c30dcc] DEBUG - [FFMPEG] - Opening '/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4' for reading
Oct 24, 2021 01:02:17.172 [0xb6c30dcc] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto'
Oct 24, 2021 01:02:17.173 [0xb6c30dcc] DEBUG - [FFMPEG] - Format mov,mp4,m4a,3gp,3g2,mj2 probed with size=2048 and score=100
Oct 24, 2021 01:02:17.173 [0xb6c30dcc] DEBUG - [FFMPEG] - ISO: File Type Major Brand: isom
Oct 24, 2021 01:02:17.174 [0xb6c30dcc] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Oct 24, 2021 01:02:17.216 [0xb6c30dcc] DEBUG - [FFMPEG] - Setting codecpar->delay to 2 for stream st: 0
Oct 24, 2021 01:02:17.216 [0xb6c30dcc] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Oct 24, 2021 01:02:17.258 [0xb6c30dcc] WARN - [FFMPEG] - stream 0, timescale not set
Oct 24, 2021 01:02:17.258 [0xb6c30dcc] DEBUG - [FFMPEG] - Before avformat_find_stream_info() pos: 1322269334 bytes read:2785702 seeks:2 nb_streams:3
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=d8 avail_size_in_buf=53668
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 0 bytes (0 bits)
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=e0 avail_size_in_buf=53666
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 16 bytes (128 bits)
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=db avail_size_in_buf=53648
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - index=0
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - qscale[0]: 2
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 67 bytes (536 bits)
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=db avail_size_in_buf=53579
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - index=1
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - qscale[1]: 5
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c2 avail_size_in_buf=53510
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - Changing bps from 0 to 8
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - sof0: picture: 518x800
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - component 0 2:2 id: 0 quant:0
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - component 1 1:1 id: 1 quant:1
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - component 2 1:1 id: 2 quant:1
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - pix fmt id 22111100
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - Format yuvj420p chosen by get_format().
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 17 bytes (136 bits)
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=53491
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=53462
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 48504 bytes
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=53436
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 4932 bytes (39456 bits)
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=48501
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 44120 bytes
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=48453
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 4333 bytes (34664 bits)
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=44110
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 43226 bytes
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=44069
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 843 bytes (6744 bits)
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=43223
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 42346 bytes
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=43183
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 837 bytes (6696 bits)
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=42340
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 39441 bytes
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=42287
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 2846 bytes (22768 bits)
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=39432
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 29474 bytes
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=39390
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 9916 bytes (79328 bits)
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 28179 bytes
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=29430
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 1251 bytes (10008 bits)
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=28173
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 27305 bytes
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=28135
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 830 bytes (6640 bits)
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=27302
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 26420 bytes
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=27265
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 845 bytes (6760 bits)
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=c4 avail_size_in_buf=26416
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - escaping removed 82 bytes
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=da avail_size_in_buf=26376
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker parser used 26294 bytes (210352 bits)
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - marker=d9 avail_size_in_buf=0
Oct 24, 2021 01:02:17.259 [0xb6c30dcc] DEBUG - [FFMPEG] - decode frame unused 0 bytes
Oct 24, 2021 01:02:17.260 [0xb6c30dcc] DEBUG - [FFMPEG] - All info found
Oct 24, 2021 01:02:17.260 [0xb6c30dcc] DEBUG - [FFMPEG] - After avformat_find_stream_info() pos: 3593697 bytes read:2818470 seeks:3 frames:14
Oct 24, 2021 01:02:17.260 [0xb6c30dcc] DEBUG - Creating /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Media/localhost/0/02939fe9fb38cc27f96a6465a9484b0b5b3ff93.bundle/Contents/Art/art1.jpg (50.0%, 1280x720).
Oct 24, 2021 01:02:17.260 [0xb6c30dcc] ERROR - [MI] Unsupported codec 'h264' for file '"/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4"'
Oct 24, 2021 01:02:17.260 [0xb6c30dcc] DEBUG - [MI] Closing input file: "/media/plexmedia/Movies/Ace Ventura - Pet Detective/Ace Ventura - Pet Detective.mp4"
Oct 24, 2021 01:02:17.264 [0xb6c30dcc] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Oct 24, 2021 01:02:17.264 [0xb6c30dcc] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/changestamp
Oct 24, 2021 01:02:17.267 [0xb6c30dcc] DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/library/changestamp (reused)
Oct 24, 2021 01:02:17.267 [0xb6c30dcc] DEBUG - Updating metadata item (save) (Ace Ventura: Pet Detective) with ID 5
Oct 24, 2021 01:02:17.271 [0xb34c2d50] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=1&metadataItemID=5&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=idle
Oct 24, 2021 01:02:17.272 [0xb34c2d50] DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=1&metadataItemID=5&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=idle (reused)
Oct 24, 2021 01:02:17.311 [0xb6c30dcc] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Oct 24, 2021 01:02:17.311 [0xb6c30dcc] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/changestamp
Oct 24, 2021 01:02:17.313 [0xb6c30dcc] DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/library/changestamp (reused)
Oct 24, 2021 01:02:17.314 [0xb6c30dcc] DEBUG - Updating metadata item (save) (Ace Ventura: Pet Detective) with ID 5
Oct 24, 2021 01:02:17.318 [0xb6c30dcc] DEBUG - HTTP requesting PUT http://127.0.0.1:32400/library/metadata/5/index?force=0
Oct 24, 2021 01:02:17.332 [0xb6c30dcc] DEBUG - HTTP/1.1 (0.0s) 200 response from PUT http://127.0.0.1:32400/library/metadata/5/index?force=0 (reused)
Here is what happens when I use “Analyze” on a video to try and trigger the thumbnail generation: output
That looks like a badly encoded file:
Test with this.
https://jell.yfish.us/media/jellyfish-15-mbps-hd-h264.mkv
(new library section ; type other videos; place this file in a new folder and add to the section)
Oct 24, 2021 10:57:28.994 [0xb4068d50] INFO - Plex Media Scanner v1.24.4.5081-e362dc1ee - Raspbian GNU/Linux PC armv7l - build: linux-armv7neon - GMT -04:00
Oct 24, 2021 10:57:28.995 [0xb4068d50] INFO - Linux version: 10 (buster), language: en-US
Oct 24, 2021 10:57:28.995 [0xb4068d50] INFO - Processor Arm
Oct 24, 2021 10:57:28.995 [0xb4068d50] INFO - /usr/lib/plexmediaserver/Plex Media Scanner --analyze --manual --server-action index --item 567 --log-file-suffix  Analysis
Oct 24, 2021 10:57:28.996 [0xb6cb1dcc] WARN - [FFMPEG] - Error loading external lib: Error loading shared library /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/be22e26-4019-linux-armv7neon/libh264_decoder.so: Operation not permitted
Oct 24, 2021 10:57:28.997 [0xb6cb1dcc] WARN - [FFMPEG] - Error loading external lib: Error loading shared library /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/be22e26-4019-linux-armv7neon/libaac_lc_decoder.so: Operation not permitted
Oct 24, 2021 10:57:28.997 [0xb6cb1dcc] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.35.5, threadsafe=1
Oct 24, 2021 10:57:29.282 [0xb6cb1dcc] DEBUG - Analyzing media parts for item 567 (Jellyfish 15 Mbps Hd): 546
Oct 24, 2021 10:57:29.283 [0xb6cb1dcc] DEBUG - [ID 546] Media part analysis: /media/plexmedia/test/jellyfish-15-mbps-hd-h264.mkv
Oct 24, 2021 10:57:29.283 [0xb6cb1dcc] DEBUG - [MI] Opening input file: "/media/plexmedia/test/jellyfish-15-mbps-hd-h264.mkv"
Oct 24, 2021 10:57:29.284 [0xb6cb1dcc] DEBUG - [FFMPEG] - Opening '/media/plexmedia/test/jellyfish-15-mbps-hd-h264.mkv' for reading
Oct 24, 2021 10:57:29.284 [0xb6cb1dcc] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto'
Oct 24, 2021 10:57:29.285 [0xb6cb1dcc] DEBUG - [FFMPEG] - Format matroska,webm probed with size=2048 and score=100
Oct 24, 2021 10:57:29.286 [0xb6cb1dcc] DEBUG - [FFMPEG] - st:0 removing common factor 1000000 from timebase
Oct 24, 2021 10:57:29.286 [0xb6cb1dcc] DEBUG - [FFMPEG] - Before avformat_find_stream_info() pos: 5528 bytes read:32768 seeks:0 nb_streams:1
Oct 24, 2021 10:57:29.287 [0xb6cb1dcc] DEBUG - [FFMPEG] - nal_unit_type: 7(SPS), nal_ref_idc: 3
Oct 24, 2021 10:57:29.287 [0xb6cb1dcc] DEBUG - [FFMPEG] - nal_unit_type: 8(PPS), nal_ref_idc: 3
Oct 24, 2021 10:57:29.330 [0xb6cb1dcc] DEBUG - [FFMPEG] - All info found
Oct 24, 2021 10:57:29.330 [0xb6cb1dcc] DEBUG - [FFMPEG] - After avformat_find_stream_info() pos: 3879090 bytes read:3892437 seeks:0 frames:50
Oct 24, 2021 10:57:29.352 [0xb6cb1dcc] DEBUG - [MI]  * 810351bd55ceb1b561450e1509c24cd692f0ed00 [mkv h264/] Duration: 30030ms, 1920x1080 (1.777778) 29.970fps, bitrate=14935kbps, audio channels=0, optimizedForStreaming=0 ("/media/plexmedia/test/jellyfish-15-mbps-hd-h264.mkv")
Oct 24, 2021 10:57:29.352 [0xb6cb1dcc] DEBUG - [MI] Chapters had generic titles, clearing.
Oct 24, 2021 10:57:29.353 [0xb6cb1dcc] DEBUG - [MI] Closing input file: "/media/plexmedia/test/jellyfish-15-mbps-hd-h264.mkv"
Oct 24, 2021 10:57:29.354 [0xb6cb1dcc] DEBUG - Streams didn't change in analysis, not saving.
Oct 24, 2021 10:57:29.355 [0xb6cb1dcc] DEBUG - Updating media item 546, size=56063351, metadata_item_id=567
Oct 24, 2021 10:57:29.356 [0xb6cb1dcc] DEBUG - Updating part with ID=546 [/media/plexmedia/test/jellyfish-15-mbps-hd-h264.mkv]
Oct 24, 2021 10:57:29.356 [0xb37c3d50] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=3&metadataItemID=567&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=analyzing
Oct 24, 2021 10:57:29.357 [0xb6cb1dcc] DEBUG - [MI] Opening input file: "/media/plexmedia/test/jellyfish-15-mbps-hd-h264.mkv"
Oct 24, 2021 10:57:29.357 [0xb6cb1dcc] DEBUG - [FFMPEG] - Opening '/media/plexmedia/test/jellyfish-15-mbps-hd-h264.mkv' for reading
Oct 24, 2021 10:57:29.357 [0xb6cb1dcc] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto'
Oct 24, 2021 10:57:29.358 [0xb6cb1dcc] DEBUG - [FFMPEG] - Format matroska,webm probed with size=2048 and score=100
Oct 24, 2021 10:57:29.358 [0xb6cb1dcc] DEBUG - [FFMPEG] - st:0 removing common factor 1000000 from timebase
Oct 24, 2021 10:57:29.358 [0xb6cb1dcc] DEBUG - [FFMPEG] - Before avformat_find_stream_info() pos: 5528 bytes read:32768 seeks:0 nb_streams:1
Oct 24, 2021 10:57:29.358 [0xb37c3d50] DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=3&metadataItemID=567&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=analyzing
Oct 24, 2021 10:57:29.359 [0xb37c3d50] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=3&metadataItemID=567&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=thumbnailing
Oct 24, 2021 10:57:29.360 [0xb6cb1dcc] DEBUG - [FFMPEG] - nal_unit_type: 7(SPS), nal_ref_idc: 3
Oct 24, 2021 10:57:29.360 [0xb6cb1dcc] DEBUG - [FFMPEG] - nal_unit_type: 8(PPS), nal_ref_idc: 3
Oct 24, 2021 10:57:29.361 [0xb37c3d50] DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=3&metadataItemID=567&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=thumbnailing (reused)
Oct 24, 2021 10:57:29.398 [0xb6cb1dcc] DEBUG - [FFMPEG] - All info found
Oct 24, 2021 10:57:29.398 [0xb6cb1dcc] DEBUG - [FFMPEG] - After avformat_find_stream_info() pos: 3879090 bytes read:3892437 seeks:0 frames:50
Oct 24, 2021 10:57:29.398 [0xb6cb1dcc] DEBUG - Creating /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Media/localhost/8/10351bd55ceb1b561450e1509c24cd692f0ed00.bundle/Contents/Thumbnails/thumb1.jpg (50.0%, 720x512).
Oct 24, 2021 10:57:29.398 [0xb6cb1dcc] ERROR - [MI] Unsupported codec 'h264' for file '"/media/plexmedia/test/jellyfish-15-mbps-hd-h264.mkv"'
Oct 24, 2021 10:57:29.401 [0xb6cb1dcc] ERROR - [MI] Unsupported codec 'h264' for file '"/media/plexmedia/test/jellyfish-15-mbps-hd-h264.mkv"'
Oct 24, 2021 10:57:29.405 [0xb6cb1dcc] ERROR - [MI] Unsupported codec 'h264' for file '"/media/plexmedia/test/jellyfish-15-mbps-hd-h264.mkv"'
Oct 24, 2021 10:57:29.405 [0xb6cb1dcc] DEBUG - [MI] Closing input file: "/media/plexmedia/test/jellyfish-15-mbps-hd-h264.mkv"
Oct 24, 2021 10:57:29.406 [0xb6cb1dcc] DEBUG - [MI] Opening input file: "/media/plexmedia/test/jellyfish-15-mbps-hd-h264.mkv"
Oct 24, 2021 10:57:29.406 [0xb6cb1dcc] DEBUG - [FFMPEG] - Opening '/media/plexmedia/test/jellyfish-15-mbps-hd-h264.mkv' for reading
Oct 24, 2021 10:57:29.406 [0xb6cb1dcc] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto'
Oct 24, 2021 10:57:29.407 [0xb6cb1dcc] DEBUG - [FFMPEG] - Format matroska,webm probed with size=2048 and score=100
Oct 24, 2021 10:57:29.407 [0xb6cb1dcc] DEBUG - [FFMPEG] - st:0 removing common factor 1000000 from timebase
Oct 24, 2021 10:57:29.407 [0xb6cb1dcc] DEBUG - [FFMPEG] - Before avformat_find_stream_info() pos: 5528 bytes read:32768 seeks:0 nb_streams:1
Oct 24, 2021 10:57:29.408 [0xb6cb1dcc] DEBUG - [FFMPEG] - nal_unit_type: 7(SPS), nal_ref_idc: 3
Oct 24, 2021 10:57:29.409 [0xb6cb1dcc] DEBUG - [FFMPEG] - nal_unit_type: 8(PPS), nal_ref_idc: 3
Oct 24, 2021 10:57:29.442 [0xb6cb1dcc] DEBUG - [FFMPEG] - All info found
Oct 24, 2021 10:57:29.442 [0xb6cb1dcc] DEBUG - [FFMPEG] - After avformat_find_stream_info() pos: 3879090 bytes read:3892437 seeks:0 frames:50
Oct 24, 2021 10:57:29.442 [0xb6cb1dcc] DEBUG - Creating /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Media/localhost/8/10351bd55ceb1b561450e1509c24cd692f0ed00.bundle/Contents/Art/art1.jpg (50.0%, 1280x720).
Oct 24, 2021 10:57:29.442 [0xb6cb1dcc] ERROR - [MI] Unsupported codec 'h264' for file '"/media/plexmedia/test/jellyfish-15-mbps-hd-h264.mkv"'
Oct 24, 2021 10:57:29.442 [0xb6cb1dcc] DEBUG - [MI] Closing input file: "/media/plexmedia/test/jellyfish-15-mbps-hd-h264.mkv"
Oct 24, 2021 10:57:29.446 [0xb6cb1dcc] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Oct 24, 2021 10:57:29.446 [0xb6cb1dcc] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/changestamp
Oct 24, 2021 10:57:29.448 [0xb6cb1dcc] DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/library/changestamp (reused)
Oct 24, 2021 10:57:29.448 [0xb6cb1dcc] DEBUG - Updating metadata item (save) (Jellyfish 15 Mbps Hd) with ID 567
Oct 24, 2021 10:57:29.452 [0xb37c3d50] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=3&metadataItemID=567&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=idle
Oct 24, 2021 10:57:29.454 [0xb37c3d50] DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=3&metadataItemID=567&metadataType=1&state=-1&parentID=-1&rootID=-1&mediaState=idle (reused)
Oct 24, 2021 10:57:29.460 [0xb6cb1dcc] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Oct 24, 2021 10:57:29.460 [0xb6cb1dcc] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/changestamp
Oct 24, 2021 10:57:29.462 [0xb6cb1dcc] DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:32400/library/changestamp (reused)
Oct 24, 2021 10:57:29.462 [0xb6cb1dcc] DEBUG - Updating metadata item (save) (Jellyfish 15 Mbps Hd) with ID 567
Oct 24, 2021 10:57:29.466 [0xb6cb1dcc] DEBUG - HTTP requesting PUT http://127.0.0.1:32400/library/metadata/567/index?force=0
Oct 24, 2021 10:57:29.474 [0xb6cb1dcc] DEBUG - HTTP/1.1 (0.0s) 200 response from PUT http://127.0.0.1:32400/library/metadata/567/index?force=0 (reused)
@ChuckPa
Any ideas?
I was never able to solve this, other than getting a bigger USB drive to install the OS to and just installing PMS as normal.
