It doesn't have the pretties interface BUT it is one of the most fully featured Plex clients you can get right now and subtitles work really well on it.
It should have a high WAF (wifey acceptance factor).
With that said. I find the Samsung app to be among the best out there right now. I don't use subtitles so I can't comment on how well this works unfortunately. But you need to make sure your subtitles are working correctly.
Example. Take a show/movies that the Sumsung is having a problem with subtitle wise and try and watch the same show through the dedicated Plex Home Theater application. Does it play fine in PHT?
If it plays poorly in PHT also then you have bad subtitle which could be burned in the movie, an SRT in the same directory or a bad online version that isn't synced correctly.
Carlo
PS I wouldn't call what you have a "NAS" as it's a "SERVER". :)
And you can setup Windows Server 2012 R2 to auto login with any user account on power up. Google it.
its not releases yet but I think the Intel compute stick will be the way to go in the future. http://www.engadget.com/2015/01/07/intel-compute-stick/ meets the PHT system requirements, tiny, and will run win 8.1 I honestly can’t wait to give this little guy a try.
its not releases yet but I think the Intel compute stick will be the way to go in the future. http://www.engadget.com/2015/01/07/intel-compute-stick/ meets the PHT system requirements, tiny, and will run win 8.1 I honestly can't wait to give this little guy a try.
I saw that on engadget as well - and it looks great. Maybe I should just wait for that.
