@geoffrothman said:
Soooo I broke down and bought the hdhomerun connect to test out the dvr functionality so i can finally cut the cord. I’m viewing and recording through a 10/100 network on an older macmini. I’m in downtown chicago so reception shouldn’t be an issue but when i view directly on the mini there’s still pixelation and the motion isn’t fluid.
Does anyone know a cheap unit I could buy that would be an acceptable server for recording shows from the connect and writing the show to either a NAS or USB hd? Are the new raspberry pi 3’s fast enough to do this? btw I have a gigabit switch so preferably the NIC would also be 10/100/1000. tks!!
Disclaimer: I’m a Plex noob, and I’m not a transcoding expert.
Note the pixelation and motion problems you describe sound more like poor antenna reception to me. Best way to test your reception is to connect your antenna directly to a TV and see if you get a nice, clear picture.
Transcoding is expensive. You need a lot of CPU power to transcode. The estimate is you need about a CPU PassMark of 2000 for a single 1080p transcode. If you have need for 2 transcodes at a time, which is common, you need about a PassMark of 4,000. Here is a huge list of CPU’s and their PassMark score:
My Linux PMS has a CPU with a PassMark of just over 9,000. Since the HDHomeRun Connect does not have built-in transcoding, and it puts out an encoded stream you can’t play directly on most devices, almost certainly when you play the show, your server is having to live transcode…and as you suspect, your CPU might not be keeping up. You have some options.
First, easy thing to try is to open up the web app, find your show, open the info page, then find the “optimize” option. It is under the “…” icon for me–the “more items”. This tells your PMS to “off-line” transcode the file so the next time you want to stream the show, it’s already transcoded, and does not need to keep up live.
Buy an HDHomeRun Extend instead. It has built-in H.264 transcoding. Note some folks have reported poor quality results while others are happy with the result.
Buy a computer with a beefier CPU. See the PassMark benchmark list.
Another option that DID NOT WORK for me is in the DVR settings. Go to Device Settings and find an “EXPERIMENTAL” option to live transcode the stream as it’s being recorded. This resulted in a failed recording for me.
I’m pretty happy with my server but already wish I had an even stronger CPU. I picked up a refurb (off-lease) Dell Optiplex 7010 from my local Microcenter for $369. It’s a nice, high-quality, quiet, small-form factor computer. It came with Windows 7, which you could upgrade to 10 if desired and run great I’m sure. I wiped it and installed Ubuntu 16.04 LTS Server. You gotta be a real geek to manage a Linux server, though.
~O)
