TMDB matching does not seem to work
Hello,
I hope you are all doing well. It seems that I cannot use tmdb id to match a TV show and retrieve information from tmdb.
I tried with tmdb-79855 and the proposal is not the one from tmdb but thetvdb. You can see it as there is actually a mistake on tmdb where the overview is in french and not english (hence different from the tvdb overview) → when you use fix match, the overview is not the right one.
I also tried to change the library to tmdb but it does not work neither.
Do you have any idea by any chance ?
Thanks a lot!
Please show how you have the files named and organized - directory listing, screenshot, etc. Indicate which folder has been added to the Plex TV show library.
It’s a movie, so it’s probably getting matched to something odd in a TV library.
Name it the way you see below and put it in a movie library
WWE: The Legacy of Stone Cold Steve Austin (2008)
Hello,
thank you for your response and help.
I am trying to match: Questions pour un champion (TV Series) — The Movie Database (TMDB)
As fix match is not working, I tried to use .plexmatch as well
Here is my folder:
– .plexmatch
– Questions pour un champion - Season 2018
– Questions pour un champion - Season 2019
The file format:
QPUC_S2018E323.avi
and .plexmatch content:
tmdbid: 7985
Thanks again
You need to follow Plex naming requirements.
Plex DocumentationYour MediaNaming & Organizing Your TV Shows Files
/TV Shows <-- Folder added to TV show library
.../Questions pour un champion (2018) {tmdb-79855} <-- ShowName (year), ID optional
....../Season 2018 <-- "Season" in English
........./Questions pour un champion (2018) s2018e01.ext <-- sXXXXeYY mandatory; ext=mp4/mkv/avi/etc.
....../Season 2019
........./Questions pour un champion (2018) s2019e01.ext
tmdb-79855 and tmdb-7985 was the first problem
Both the fix match and plexmatch is probably working just fine
This is a French show and neither TVDB or TMDB has an English translation
Sorry it was a typo when I wrote the message (sorry!), I indeed have tmdbid: 79855 in the plex file
Thanks for pointing out to the missing translation, it is helpful. Do you know if we can force the language in .plexmatch file, in order to select the french version ?
Also, tmdb has english name for the episodes but it is not picked neither. I tried updating the folder name but still no luck.
When I try to fix match with tmdb-79855, it seems I still get tvdb and not tmdb
while the overview is different in tmdb:
I will continue trying and keep you posted
Thanks!
Edit: I added an English description for the show at TMDB and TVDB. Plex should pick it up in two or three days.
The TVDB and TMDB IDs are used only for matching. They do not affect what information is displayed for the series or episodes.
Plex defaults to using the TMDB episode ordering. You might try changing that to TVDB Aired, then refreshing the metadata. Edit the show (pencil icon), choose Advanced, change Episode Ordering, then save changes and refresh the metadata for the show.
What you are experiencing happens sometimes when TMDB and TVDB have different information or lack information (such as an English description).
If TVDB/TMDB has information is available in the same language as the Plex library, then Plex will use it. If not, it may use information from other languages or may just leave things blank (I haven’t tested this in awhile).
Both sites have user contributed information and let users edit what is available.
You could edit the show description on either site, adding an English translation.
Plex should pick up any changes within two to three days.
Thank you all, I will wait a couple of days then and update you :slight_smile:
