To the developer of Plex (Audio Solution)
The issue is with Plex and not TVS,I found this out by using RarFlix and Rarflix has an option (even on Your Roku
while movie is playing You can go to options of Rarflix and choose audio options are leveling,off.and night
when set to night or leveling it is like being at Woodstock the volume jumped so loud i had to lower my TV to 65
To the developer of Plex,if You can somehow implement the same Audio Codecs ,or Recipe that Rarflix has,
then that would be everyone’s solution
Thank You
Duplicate
