Trailer is unavailable. Try again later (please help)
I get this message after completing all the steps.
Im using a windows 7 to do all this and have an apple tv 3 (5.1.1)
When I double click PlexConnect.py and a command window opens.. I get "serving http on 0.0.0.0 port 80. -- which is correct i believe.
I changed the DNS to the ip address listed in the command window.
couple lines above it says DNSServer: failed to creak socket to UDP port 53: (errno 10048) only one usage of each socket adddres
HOWEVER....  if i open the plexconnect.(complied python file) .. the error message i get is "PLEX MEDIA SERVER - unknown error)
What else should i try?
Thanks!!
Please read the sticky on how to report an error.
Or look on the wiki for troubleshooting common errors such as your port 53 one.
