So say for example, I have a 10GB file that is 60 minutes long.
If I have the transcode buffer set at 60 seconds (1% of file) does that mean that Plex stores 1% of the above file at any one time in the transcode buffer folder?
The transcoder prefers to leave the previously transcoded segments until you’re done so you are free to seek all the way back to the beginning if you want.
If the space is small, it will start deleting the oldest segments to make room for what you’re playing now.
The question becomes: How many minutes of Seek-Backwards do you want?
