"Transcode runner appears to have died"
On my FreeNAS, suddenly Plex can’t play any content that requires transcoding. Looking at the logs I see
I’ve tried optimizing database, reinstalling Plex in a new jail (I have Plexpass), rolling back to a prior configuration… nothing works. I’m stuck.
To be clear, no content plays on web, iOS or Roku, so it’s not client-specific.
Let’s get some debug mode server logs zipped and uploaded if you like.
I would suggest you restart the hardware, give it 6min to fully initialize, then express the issue, wait a minute, and download log files.
Logs
OK, I’ve attached them. Feel free to take a gander.
Plex Media Server Logs_2019-11-07_11-53-43.zip (36.4 KB)
thank you sir I will.
EDIT: I looked the logs @richard_kiss and after the transcode session starts, PMS complains about timestamps in the MP4. Because the video you watched started out as an MKV, I’m guessing there’s a real problem with the transcoded MP4.
Here is the section of the log showing the video playback problem:
Nov 07, 2019 11:52:37.606 [0x8152f0000] ERROR - [Transcoder] [mp4 @ 0x803aa1400] Application provided duration: -32 / timestamp: 59280808 is out of range for mov/mp4 format
Nov 07, 2019 11:52:37.707 [0x8152f0000] ERROR - [Transcoder] [mp4 @ 0x803aa1400] Application provided duration: -32 / timestamp: 62475688 is out of range for mov/mp4 format
Nov 07, 2019 11:52:37.975 [0x816c65000] ERROR - [Transcoder] [mp4 @ 0x803aa1400] Application provided duration: -32 / timestamp: 70875544 is out of range for mov/mp4 format
Nov 07, 2019 11:52:38.035 [0x80bae4400] DEBUG - Jobs: '/usr/local/share/plexmediaserver-plexpass/Plex Transcoder' exit code for process 2075 is 0 (success)
Nov 07, 2019 11:52:38.071 [0x80c36c200] DEBUG - Auth: authenticated user 1 as richard.kiss
Nov 07, 2019 11:52:38.071 [0x816c65000] DEBUG - Request: [192.168.1.222:15163 (Subnet)] GET /status/sessions (7 live) GZIP Signed-in Token (richard.kiss)
Nov 07, 2019 11:52:38.071 [0x816c65000] DEBUG - [Now] Adding 0 sessions.
Nov 07, 2019 11:52:38.072 [0x80c36c200] DEBUG - Completed: [192.168.1.222:15163] 200 GET /status/sessions (7 live) GZIP 1ms 429 bytes (pipelined: 1)
Nov 07, 2019 11:52:38.073 [0x817058a00] WARN - Transcode runner appears to have died.
Nov 07, 2019 11:52:38.073 [0x814ee8f00] WARN - Transcode runner appears to have died.
Nov 07, 2019 11:52:38.173 [0x817058a00] WARN - Timed out waiting for segment.
Because you said it happens to any video that requires transcoding, please restart PMS, give it 6min to initialize, then test again with another video that you’ve played before without problems. Upload the logs for that test also. We’ll be able to see if the common problem is MP4 timestamps from the transcoder.
On my system, I can’t recreate the problem. I tried with and without hardware acceleration.
I tried installing the “plex” plug-in on FreeNAS instead of the “plex-plexpass” plug-in, and my problems seem to have resolved. Even though I’ve paid for the Plex Pass.
