Transcoder Crashing after update to Plex Pass v. 1.11.1.4730 from 1.9.x
@sa2000 said:
I will try and find the post
there were 2 users that went for the parent directory and there is also a post from me saying that I came across advice for other apps to rename the parent directory
you can try if you are ok with it
http://forums.plex.tv/discussion/comment/1512015/#Comment_1512015
http://forums.plex.tv/discussion/comment/1496973/#Comment_1496973
http://forums.plex.tv/discussion/comment/1497423/#Comment_1497423
And we are fixed.
WOOO
And we are fixed.
WOOO
Wow
So needed to rename the crypto folder ?
was it just Keys and RSA or more subdirectories?
And we are fixed.
WOOO
Wow
It just re-created the RSA folder, then the file inside.
Makes no sense - but that’s Windows.
Let me say this a different way - I renamed the RSA folder (backup), and then restarted the service, it made the RSA folder immediately - and worked that time.
I did not delete the krypto parent directory - I was just going to, but I wanted to hedge my bet and try it one more time. This time it worked.
And we are fixed.
WOOO
Wow
Thanks - so for the issue remaining at 16:52 was because you did not do the renaming of the RSA folder which was the step on the article.
Thanks for the feedback
