Installed the newest beta today and have been testing out HEVC transcoding using an nVidia RTX 4060. It seems as though the throttle buffer is not being respected, both for HEVC transcoding and H264 transcoding. My throttle buffer is set to 60 (the default I believe), but when transcoding a video it transcodes the entirety of the stream before stopping. I have tried changing the throttle buffer to different times, but none have fixed the issue, nor has restarting the server. I assume this is a bug in the beta release?
Server Version#: 1.41.4.9399
Server OS: Windows Server 2022
Player Version#: Roku 7.30.24.9821-1020931ea-Plex
Edit: It appears from the update notes this is… intended behavior. That’s disappointing given transcoding pegs the GPU at 100% usage for the entirety of the transcode, which for some movies is upwards of 40 minutes. While the GPU is pegged at 100%, additional transcode streams fail to start due to buffering. Whereas before the GPU was at 100% for maybe a minute, and then spiked briefly throughout the rest of the watch time, allowing others to use those resources.
