Transcoder segfault in ld-musl-x86_64.so
I cannot find this, logging into the container I see:
# ls
ld-musl-x86_64.so.1          libboost_random.so  libdrm_radeon.so.1    libnghttp2.so               libswresample.so.4
libavcodec.so.59             libboost_regex.so   libeditline.so.1      libonnxruntime.so.1.16.3    libswscale.so.6
libavfilter.so.8             libboost_system.so  libfmt.so.8           libopencv_core.so.405       libtag.so.1
libavformat.so.59            libboost_thread.so  libfreeimage.so       libopencv_dnn.so.405        libusb-1.0.so.0
libavutil.so.57              libboost_timer.so   libgcompat.so.0       libopencv_imgcodecs.so.405  libva-drm.so.2
libboost_atomic.so           libc++.so.2         libhdhomerun.so       libopencv_imgproc.so.405    libva.so.2
libboost_chrono.so           libc.so             libiconv.so.2         libpciaccess.so.0           plexmediaserver.default
libboost_date_time.so        libcharset.so.1     libicudataplex.so.69  libpion.so                  plexmediaserver.init
libboost_filesystem.so       libcrypto.so.3      libicui18nplex.so.69  libpython27.so              plexmediaserver.service
libboost_iostreams.so        libcurl.so.4        libicuioplex.so.69    libsoci_core.so
libboost_json.so             libdrm.so.2         libicuucplex.so.69    libsoci_sqlite3.so
libboost_locale.so           libdrm_amdgpu.so.1  libigdgmm.so.12       libsqlite3.so
libboost_program_options.so  libdrm_intel.so.1   libminiupnpc.so.17    libssl.so.3
# pwd
/usr/lib/plexmediaserver/lib
# find / -xdev -name '*4673*'
# find / -xdev -name '*codec*'
/usr/lib/plexmediaserver/Resources/Plug-ins-c67dce28e/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/pyamf/codec.py
/usr/lib/plexmediaserver/lib/libavcodec.so.59
/usr/lib/plexmediaserver/lib/libopencv_imgcodecs.so.405
As per I above I suspect codecs are under /usr/lib/plexmediaserver/lib ?
Never mind, I deleted the whole container and reinstalled which pulled everything fresh.
Will see how I get on with it…
Unfortunately, that won’t do it. The codecs actually live in your Plex data folder, which is generally preserved. It’s the folder you map to /config in your container, in ./Library/Application Support/Plex Media Server/Codecs.
OK deleted all the codecs under /Library/Application Support/Plex Media Server/Codecs/ad47460-4673-linux-x86_64, on restarting and playing video I can see it downloads them again (although they are the same size as the old one’s I backed up first).
There have been times when updated versions are still the same exact size because the replacement code, when compiled, is the same binary file size.
Unfortunately it is still segfaulting, eg:
ay 10 02:10:18 Tower kernel: Plex Transcoder[5374]: segfault at 153ce3482000 ip 0000153ce5d17204 sp 0000153ce307196
8 error 4 in ld-musl-x86_64.so.1[153ce5cd2000+53000] likely on CPU 3 (core 3, socket 0)
May 10 02:10:18 Tower kernel: Code: 75 f4 c3 cc cc cc 48 89 f8 48 83 fa 08 72 14 f7 c7 07 00 00 00 74 0c a4 48 ff ca
 f7 c7 07 00 00 00 75 f4 48 89 d1 48 c1 e9 03 <f3> 48 a5 83 e2 07 74 05 a4 ff ca 75 fb c3 cc cc 48 89 f8 48 29 f0
May 10 02:10:20 Tower kernel: Plex Transcoder[5521]: segfault at 145f49731000 ip 0000145f4bfd6204 sp 0000145f4943796
8 error 4 in ld-musl-x86_64.so.1[145f4bf91000+53000] likely on CPU 7 (core 3, socket 0)
May 10 02:10:20 Tower kernel: Code: 75 f4 c3 cc cc cc 48 89 f8 48 83 fa 08 72 14 f7 c7 07 00 00 00 74 0c a4 48 ff ca
May 10 02:10:23 Tower kernel: Plex Transcoder[5649]: segfault at 14d9a2834000 ip 000014d9a50f2204 sp 000014d9a23e996
8 error 4 in ld-musl-x86_64.so.1[14d9a50ad000+53000] likely on CPU 2 (core 2, socket 0)
May 10 02:10:23 Tower kernel: Code: 75 f4 c3 cc cc cc 48 89 f8 48 83 fa 08 72 14 f7 c7 07 00 00 00 74 0c a4 48 ff ca
May 10 02:10:27 Tower kernel: Plex Transcoder[5737]: segfault at 14abe2e19000 ip 000014abe572a204 sp 000014abe2b9396
8 error 4 in ld-musl-x86_64.so.1[14abe56e5000+53000] likely on CPU 3 (core 3, socket 0)
May 10 02:10:27 Tower kernel: Code: 75 f4 c3 cc cc cc 48 89 f8 48 83 fa 08 72 14 f7 c7 07 00 00 00 74 0c a4 48 ff ca
May 10 02:10:30 Tower kernel: Plex Transcoder[5902]: segfault at 14bb2f3c1000 ip 000014bb31c94204 sp 000014bb2f10a96
8 error 4 in ld-musl-x86_64.so.1[14bb31c4f000+53000] likely on CPU 2 (core 2, socket 0)
May 10 02:10:30 Tower kernel: Code: 75 f4 c3 cc cc cc 48 89 f8 48 83 fa 08 72 14 f7 c7 07 00 00 00 74 0c a4 48 ff ca
May 10 02:10:33 Tower kernel: Plex Transcoder[6025]: segfault at 151816da9000 ip 00001518192cd204 sp 000015181681996
8 error 4 in ld-musl-x86_64.so.1[151819288000+53000] likely on CPU 7 (core 3, socket 0)
the codecs are all new:
root@Tower:/mnt/user/appdata/plex/Library/Application Support/Plex Media Server/Codecs/ad47460-4673-linux-x86_64# ls -l
total 5056
-rw-r--r-- 1 nobody users  203944 May  8 14:58 libaac_encoder.so
-rw-r--r-- 1 nobody users  275016 May  8 15:03 libaac_latm_decoder.so
-rw-r--r-- 1 nobody users 1596512 May  8 15:03 libh264_decoder.so
-rw-r--r-- 1 nobody users 1509952 May  8 14:58 libhevc_decoder.so
-rw-r--r-- 1 nobody users  124984 May  8 14:58 libmp2_decoder.so
-rw-r--r-- 1 nobody users  124984 May  9 08:30 libmp3_decoder.so
-rw-r--r-- 1 nobody users  553184 May  8 14:58 libmpeg2video_decoder.so
-rw-r--r-- 1 nobody users  772640 May  9 03:11 libmpeg4_decoder.so
This failure is happening during scheduled tasks, I have this configured:
Looking at the logs specifically I believe “Generating video preview thumbnails” is causing the issue, if you can run my file through that task on your systems then you should be able to re-create the fault.
Thank you. I"ll do that now.
Just wondered if you had time to re-create the issue?
Been trying to recreate it but haven’t.
By definition, I should easily recreate it as I have the same exact binary files.
The only difference here is the CPU.
You have the i7-7700 (KabyLake) ?
I have one in my QNAP; which is almost done reshaping the volume to 128TB (8x20)
My i7-8809 can’t recreate it.
Strange, perhaps it is related to kernel version also, I am on 6.1.79 (unRAID).
Yes, i7-7700 Kaby Lake.
I got rid of all the terrible-quality files that were causing segfaults. I then discovered another recording that’s decent quality, but caused a segfault a few days ago:
May 17, 2024 04:57:23.441 [140087610325816] DEBUG - Activity: registered new activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - "Generating video preview thumbnails"
May 17, 2024 04:57:23.441 [140087610325816] DEBUG - [JobRunner] Job running: FFMPEG_EXTERNAL_LIBS='/var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Codecs/ad47460-4673-linux-x86_64/' X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx "/usr/lib/plexmediaserver/Plex Transcoder" -codec:v h264 -skip_frame:v nokey -i "/shared/video/Recorded Movies/Hannibal (2001)/Hannibal (2001).ts" -threads 0 -nostats -q 3 -loglevel quiet -filter_complex "[0:V:0] fps=fps=0.500000:round=up,scale=w=320:h=240:force_original_aspect_ratio=decrease [out]" -map "[out]" "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Media/localhost/a/a1cee927cf4268b26716d47e48727150eedfb26.bundle/Contents/Indexes/tmp/img-%06d.jpg" -progressurl http://127.0.0.1:32400/video/:/transcode/session/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5/progress
May 17, 2024 04:57:23.441 [140087610325816] DEBUG - [JobRunner] In directory: "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Media/localhost/a/a1cee927cf4268b26716d47e48727150eedfb26.bundle/Contents/Indexes"
May 17, 2024 04:57:23.442 [140087610325816] DEBUG - [JobRunner] Jobs: Starting child process with pid 555028
May 17, 2024 04:57:23.446 [140087587220280] DEBUG - Request: [127.0.0.1:47224 (Loopback)] PUT /video/:/transcode/session/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5/progress?status=startup (5 live) #43d716 Signed-in Token (username) (range: bytes=0-)
May 17, 2024 04:57:23.447 [140088045898552] DEBUG - Completed: [127.0.0.1:47224] 206 PUT /video/:/transcode/session/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5/progress?status=startup (5 live) #43d716 0ms 371 bytes (pipelined: 1) (range: bytes=0-)
May 17, 2024 04:57:23.449 [140087587220280] DEBUG - Request: [127.0.0.1:47224 (Loopback)] PUT /video/:/transcode/session/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5/progress?status=startup (5 live) #43d7f9 Signed-in Token (username) (range: bytes=0-)
May 17, 2024 04:57:23.449 [140088048007992] DEBUG - Completed: [127.0.0.1:47224] 206 PUT /video/:/transcode/session/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5/progress?status=startup (5 live) #43d7f9 0ms 371 bytes (pipelined: 2) (range: bytes=0-)
May 17, 2024 04:57:23.450 [140087587220280] DEBUG - Request: [127.0.0.1:47224 (Loopback)] PUT /video/:/transcode/session/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5/progress?status=opening (5 live) #43d7fa Signed-in Token (username) (range: bytes=0-)
May 17, 2024 04:57:23.450 [140088045898552] DEBUG - Completed: [127.0.0.1:47224] 206 PUT /video/:/transcode/session/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5/progress?status=opening (5 live) #43d7fa 0ms 371 bytes (pipelined: 3) (range: bytes=0-)
May 17, 2024 04:57:23.513 [140087587220280] DEBUG - Request: [127.0.0.1:47224 (Loopback)] PUT /video/:/transcode/session/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5/progress?status=opened (5 live) #43d7fb Signed-in Token (username) (range: bytes=0-)
May 17, 2024 04:57:23.513 [140088048007992] DEBUG - Completed: [127.0.0.1:47224] 206 PUT /video/:/transcode/session/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5/progress?status=opened (5 live) #43d7fb 0ms 371 bytes (pipelined: 4) (range: bytes=0-)
May 17, 2024 04:57:23.514 [140087587220280] DEBUG - Request: [127.0.0.1:47224 (Loopback)] PUT /video/:/transcode/session/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5/progress/stream?index=0&id=256&codec=h264&type=video (5 live) #43d7fc Signed-in Token (username) (range: bytes=0-)
May 17, 2024 04:57:23.514 [140088045898552] DEBUG - Completed: [127.0.0.1:47224] 404 PUT /video/:/transcode/session/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5/progress/stream?index=0&id=256&codec=h264&type=video (5 live) #43d7fc 0ms 288 bytes (pipelined: 5) (range: bytes=0-)
May 17, 2024 04:57:23.514 [140087587220280] DEBUG - Request: [127.0.0.1:47232 (Loopback)] PUT /video/:/transcode/session/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5/progress/stream?index=0&id=256&codec=h264&type=video (5 live) #43d7f8 Signed-in Token (username) (range: bytes=0-)
May 17, 2024 04:57:23.515 [140088048007992] DEBUG - Completed: [127.0.0.1:47232] 404 PUT /video/:/transcode/session/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5/progress/stream?index=0&id=256&codec=h264&type=video (5 live) #43d7f8 0ms 288 bytes (pipelined: 1) (range: bytes=0-)
May 17, 2024 04:57:23.515 [140087587220280] DEBUG - Request: [127.0.0.1:47242 (Loopback)] PUT /video/:/transcode/session/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5/progress/stream?index=1&id=257&codec=ac3&type=audio (5 live) #43d7ff Signed-in Token (username) (range: bytes=0-)
May 17, 2024 04:57:23.515 [140088048007992] DEBUG - Completed: [127.0.0.1:47242] 404 PUT /video/:/transcode/session/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5/progress/stream?index=1&id=257&codec=ac3&type=audio (5 live) #43d7ff 0ms 288 bytes (pipelined: 1) (range: bytes=0-)
May 17, 2024 04:57:23.591 [140087587220280] DEBUG - Request: [127.0.0.1:47246 (Loopback)] PUT /video/:/transcode/session/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5/progress/streamDetail?index=0&id=256&codec=h264&type=video&profile=High&width=704&height=480&interlaced=0&sar=1:1&level=30&frameRate=29.970&closedCaptions=1 (5 live) #43d802 Signed-in Token (username) (range: bytes=0-)
May 17, 2024 04:57:23.591 [140088045898552] DEBUG - Completed: [127.0.0.1:47246] 404 PUT /video/:/transcode/session/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5/progress/streamDetail?index=0&id=256&codec=h264&type=video&profile=High&width=704&height=480&interlaced=0&sar=1:1&level=30&frameRate=29.970&closedCaptions=1 (5 live) #43d802 0ms 288 bytes (pipelined: 1) (range: bytes=0-)
May 17, 2024 04:57:23.592 [140087587220280] DEBUG - Request: [127.0.0.1:47248 (Loopback)] PUT /video/:/transcode/session/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5/progress/streamDetail?index=1&id=257&codec=ac3&type=audio&bitrate=128000&channels=2&layout=stereo&sampleRate=48000 (5 live) #43d805 Signed-in Token (username) (range: bytes=0-)
May 17, 2024 04:57:23.592 [140088045898552] DEBUG - Completed: [127.0.0.1:47248] 404 PUT /video/:/transcode/session/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5/progress/streamDetail?index=1&id=257&codec=ac3&type=audio&bitrate=128000&channels=2&layout=stereo&sampleRate=48000 (5 live) #43d805 0ms 288 bytes (pipelined: 1) (range: bytes=0-)
May 17, 2024 04:57:23.594 [140087587220280] DEBUG - Request: [127.0.0.1:47254 (Loopback)] PUT /video/:/transcode/session/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5/progress?duration=6693.400022 (5 live) #43d808 Signed-in Token (username) (range: bytes=0-)
May 17, 2024 04:57:23.594 [140088045898552] DEBUG - Completed: [127.0.0.1:47254] 206 PUT /video/:/transcode/session/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5/progress?duration=6693.400022 (5 live) #43d808 0ms 371 bytes (pipelined: 1) (range: bytes=0-)
May 17, 2024 04:57:23.730 [140087587220280] DEBUG - [Req#43d80c/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 0.0% - Generating video preview thumbnails
May 17, 2024 04:57:24.226 [140087587220280] DEBUG - [Req#43d811/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 3.2% - Generating video preview thumbnails
May 17, 2024 04:57:24.727 [140087587220280] DEBUG - [Req#43d816/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 6.0% - Generating video preview thumbnails
May 17, 2024 04:57:25.231 [140087587220280] DEBUG - [Req#43d81b/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 9.1% - Generating video preview thumbnails
May 17, 2024 04:57:25.731 [140087587220280] DEBUG - [Req#43d820/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 11.1% - Generating video preview thumbnails
May 17, 2024 04:57:26.235 [140087587220280] DEBUG - [Req#43d825/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 12.9% - Generating video preview thumbnails
May 17, 2024 04:57:26.738 [140087587220280] DEBUG - [Req#43d82a/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 15.6% - Generating video preview thumbnails
May 17, 2024 04:57:27.238 [140087587220280] DEBUG - [Req#43d82f/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 19.2% - Generating video preview thumbnails
May 17, 2024 04:57:27.741 [140087587220280] DEBUG - [Req#43d834/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 23.0% - Generating video preview thumbnails
May 17, 2024 04:57:28.240 [140087587220280] DEBUG - [Req#43d839/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 26.5% - Generating video preview thumbnails
May 17, 2024 04:57:28.741 [140087587220280] DEBUG - [Req#43d83e/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 28.8% - Generating video preview thumbnails
May 17, 2024 04:57:29.247 [140087587220280] DEBUG - [Req#43d843/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 32.0% - Generating video preview thumbnails
May 17, 2024 04:57:29.747 [140087587220280] DEBUG - [Req#43d848/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 34.7% - Generating video preview thumbnails
May 17, 2024 04:57:30.247 [140087587220280] DEBUG - [Req#43d84d/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 37.1% - Generating video preview thumbnails
May 17, 2024 04:57:30.750 [140087587220280] DEBUG - [Req#43d852/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 39.6% - Generating video preview thumbnails
May 17, 2024 04:57:31.250 [140087587220280] DEBUG - [Req#43d857/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 42.3% - Generating video preview thumbnails
May 17, 2024 04:57:31.750 [140087587220280] DEBUG - [Req#43d85c/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 44.5% - Generating video preview thumbnails
May 17, 2024 04:57:32.251 [140087587220280] DEBUG - [Req#43d861/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 47.0% - Generating video preview thumbnails
May 17, 2024 04:57:32.754 [140087587220280] DEBUG - [Req#43d866/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 48.6% - Generating video preview thumbnails
May 17, 2024 04:57:33.253 [140087587220280] DEBUG - [Req#43d86b/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 51.0% - Generating video preview thumbnails
May 17, 2024 04:57:33.754 [140087587220280] DEBUG - [Req#43d870/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 54.3% - Generating video preview thumbnails
May 17, 2024 04:57:34.253 [140087587220280] DEBUG - [Req#43d875/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 56.8% - Generating video preview thumbnails
May 17, 2024 04:57:34.753 [140087587220280] DEBUG - [Req#43d87a/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 59.9% - Generating video preview thumbnails
May 17, 2024 04:57:35.259 [140087587220280] DEBUG - [Req#43d87f/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 62.5% - Generating video preview thumbnails
May 17, 2024 04:57:35.764 [140087587220280] DEBUG - [Req#43d884/Transcode/bif/ad1e7330-3792-47a1-8aa3-681bd5b6f5b5] Activity: updated activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5 - completed 65.5% - Generating video preview thumbnails
May 17, 2024 04:57:36.100 [140088052828984] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 555028 is -11 (signal: Segmentation fault)
May 17, 2024 04:57:36.100 [140087610325816] ERROR - BaseIndexFrameFileManager: transcoder exited abnormally
May 17, 2024 04:57:36.253 [140087610325816] DEBUG - Updating part with ID=107636 [/shared/video/Recorded Movies/Hannibal (2001)/Hannibal (2001).ts]
May 17, 2024 04:57:36.254 [140087610325816] DEBUG - Activity: Ended activity ad1e7330-3792-47a1-8aa3-681bd5b6f5b5.
Here’s the file:
