Transcoding Throttled
Got it now
Ian, I apologize, but in my rush I copied Plex Media Sever Log 1. I am attaching the log without any numbers after it.
Yeah i'm having an issue with playback.  it pauses every few seconds for buffering on a 1080p/dts file. I tested the stream to my popcorn hour a400 and it streams fine over there.  (same network hookup as my xbox) 1gig LAN back to my server that has all of the storage.
1. quality set to highest.
2. Activity > Now playing > info Direct stream for audio and video.
Media
  • Video Resolution 1080p
  • Duration 2:45:07
  • Bitrate 9474 kbps
  • Width 1920
  • Height 800
  • Aspect Ratio 2.35
  • Container MKV
  • Video Frame Rate 24p
  • ideo
    • Codec H264
    • Bitrate 8835 kbps
    • Language English
    • Bit Depth 8
    • CABAC 1
    • Chroma Subsampling 4:2:0
    • Color Space yuv
    • Duration 2:45:07
    • Frame Rate 23.976 fps
    • Frame Rate Mode cfr
    • Has Scaling Matrix 0
    • Height 800
    • Level 4.1
    • Profile high
    • Ref Frames 5
    • Scan Type progressive
    • Width 1920
    Audio
    • Codec AC3
    • Channels 5.1
    • Bitrate 640 kbps
    • Language English
    • Bit Depth 16
    • Bitrate Mode CBR
    • Dialog Norm -31 dB
    • Duration 2:45:07
    • Sampling Rate 48000 Hz
    Subtitles
    • Codec IDX
    • Sub Index 0
    • Language English
    • Format VOBSUB
    Subtitles
    • Codec IDX
    • Sub Index 1
    • Language English
    • Format VOBSUB
    Subtitles
    • Forced 1
    • Codec SRT
    • Language English
    • Format SRT
also my cpu was at 35-60% during the playback. (all plex, nothing else taking up cpu cycles)
Thanks for the logs. I've pinged one of the server developers to see if they can take a look for us.
Ian
I tested another video.  It was playing OK, but this i suspect it was a much lower throughput because for whatever reason Plex was transcoding the audio to AAC.
AUDIO English (DTS 5.1)
<span style="color:#000000;">Audio</span>
  • Codec DCA
  • Channels 5.1
  • Bitrate 1509 kbps
  • Language English
  • Bit Depth 24
  • Bitrate Mode CBR
  • Duration 2:11:35
  • Profile es
Thanks Ian. It is running smoother now, but I am not really sure why. I have tested various 1080P files and they don't seem to be stuttering anymore.
same here,  i had changed it to highest quality during my first run.  When i checked the logs i saw the bittrate was pretty low,  around 4-6mbps.  After exiting the movie and restarting now im seeing 9-12mps for a bit rate and no more stuttering.  but not sure why some of the movies are not doing direct play.
audio sounds odd too.  but maybe im just nit picking here hehe
^Audio is most likely because of....  That stinks, all of my stuff is either in DTS, or DTS-HD.  and yes while i get it transcodes to AC3 i want it to just pass-through the audio to my receiver.
Does the application support DTS?
No. At present, there is no support for 3rd party applications to play DTS. However, Plex Media Server will transcode DTS audio into AC3 in order to preserve the surround sound audio channels. We're working with Microsoft to bring DTS playback support in the future.
Does the following line refer to the bitrate the video is playing at or the bitrate that the Plex App is receiving data at?
Oct 07, 2014 17:05:04 [0x103e81000] DEBUG - HLS segment range: 0 - 817 average bitrate: 4.50 Mbps
You mentioned earlier that it appeared to get better for a short time. Could this coincide when other people/clients are streaming from the same server? I'm wondering if there might be issues with multiple clients at the same time effecting each other too much. Does that sound plausible?
Ian
