Direct play, buffering and throttled at the same time
Server Version#: 1.13.5.291
Player Version#: 3.69.1
How can I have all of these at the same time? I search for throttled brings up this page. Which says that throttled means that the server throttling down because it can perform the transcode faster than is required. However, in my case it not transcoding.
If in, this case, throttling means that the server can pass untranscoded media faster than is required, and so is throttling down, why is it buffering? If it is buffering, that would suggest that the server should be working as hard as possible, not throttling down.
post logs from when the issue is happening.
Have you verified that Plex is seeing your ATV as a LAN device and not WAN?
