Transferring library to new NVIDIA - SHIELD Android TV Pro
THANK YOU SO MUCH :slightly_smiling_face:
So, did it work?
I am still waiting on the delivery of my new Shield. It got delayed :pensive:
Will update!
Just wished there was a simpler backup and restore function for Plex data libraries.
It’s really completely unacceptable in 2020 that there’s still not an easy method for backing up your PMS library/data and being able to restore it in case of distaster, or simply move it to a new Shield. It really should be a one or two click process.
I’m dreading the day I have to do go through what jay8393 is going through.
It took me 2 hours, but finally managed to get it to work!!! I couldn’t figure out why there was no option to select storage location, which would have been next to the PMS settings. Finally figured out that I had to set up Plex of the new Shield via the Plex web app, which eventually enabled the storage location settings. And I didn’t realise that the ā€˜name’ of the PMS would be retained in the new Shield TV, as I setup a new ā€˜name’ to differentiate between the new and old. That created confusion for me.
It wasn’t as ā€˜simple’ as I thought it was, but I am happy to transfer everything across to the new Shield TV. Again, I wished there was just a simple ā€˜backup’ in settings.
Thank you again!
Yeah, transferring means to transfer everything, including the name. Glad to hear you got it all figured out.
