Transmission plugin
Why does in land in my 'videos' section?
Hey,
First off, a huge thanks to Elan and the rest of you for all your hard work and tireless effort on Plex. It is marvy.
Also, I just tried the Transmission plug-in. It's fantastic. I did have one question about it though... for some reason it shows up in my videos section rather than my applications section. How do I get it to the right place?
Thanks in advance, and again.
This has nothing to do with you, and everything to do with the plugin. At the moment, the Transmission plugin registers itself under the video plugins section of Plex instead of the applications section. There was a recent change (like yesterday I think) that changes this and moves it into the applications section, however the update hasn’t been approved yet. Once it does (and I hope it is soon since I want it moved to the applications section too) then you should get a notification that it needs to be updated (or, at least I think you will get notified…it is in the app store so I think you do)
Hope that answers your question!
Many thanks!
