How do I launch a Plugin? Not visible in the Plex Menu
Server Version#: 4.51.3
Player Version#: 4.51.3
I have downloaded and installed the GitHub - kolsys/YouTubeTV.bundle: Plex YouTube video plugin. After restarting, I see this bundle is ready for configuration under Settings > Manage > Plugins. However, I do not see the bundle anywhere in the Plex Menu - ie, I can’t see any way to launch the plugin. What am I missing? I have a Plex Pass subscription. Do I need to upgrade to Premium? Is there some other configuration/switch that needs to be enabled?
These kind of plug-ins previously known as channels are now sunset and should not work (as intended). There are only a small handful of plug-ins that are still allowed but are ONLY management tools such as WebTools.
Is there any alternative to plugins - can developers build their own “web shows” for example?
:skull: Plugins : This was not a decision taken lightly, as they’ve been around for a long time, and we’ve had good times both writing and using them. But bluntly, hardly anyone uses them (less than 2% of users), the ancient protocol they use is a continued pain for clients to support, and if we were to build the feature again, we’d do it very differently in this day and age. For utility-type functionality, we love standalone apps like Tautulli and believe this is a better approach. But don’t panic—while the Plugin Directory will soon be gone, you can still manually install plugins for the foreseeable future.
Excerpted from → Blog 2018
However they completely eliminated use of what you’re asking to do - access to outside video and music services as plug-ins. I miss them as well, but there isn’t any intent for them to bring them back - so they say.
Disappointing. I was scripting for Playon.tv but Plex would be a more universal platform.
Agreed. Most devs have opted to develop scripts that work outside of Plex such as the DizqueTV project. or xTeVe - IPTV for Plex DVR
GitHub - vexorian/dizquetv: Create live TV channels from your own media. Access the streams using the simulated HDHomerun tuner or the generated M3U URl.
Thanks for the tip. I will read up on these.
