Stats are a lot of fun indeed:
awesome!
Your stat pages looks like mine....I'm going to try and figure out a way to prune back the genre's & consolidate the content ratings
Sorry about the wait for Firefox users, it's been a week since my last update submission and I'm still only halfway through the review queue!
In the meantime I'm open to ideas for other statistics/data you guys want to see on the stats page.
So the stats functionality is not in firefox yet? I tried the 1.1 version of plugin and never could find out how to view stats but did see option to enable stats in prefs which is enabled.
Unfortunately not, it hasn't been reviewed yet. You can install the latest unapproved version here though. The stats page link appears next to the 'now playing' link in the top right of the navbar in plex/web.
Thanks. I kept checking everyday hoping Firefox would get a move on but no luck. I've always preferred FF but they seriously need to speed up their process for things like this or I might finally be pushed into using Chrome full time.
Thanks again for your excellent addon. I realised the other day when I didn't have access to it just how much it's become absolutely essential to my Plex use and how quickly I miss it.
Running firefox 34.0. Plugin appears to work because it gives splash screen and i click on link in splash screen and shows stats. Very cool.
However, I see nothing in upper right nav to click on. Look all around on home page and in each section and did not see anything. Maybe something with my version of firefox since devel version.
After you refresh the page the icon should appear here
If you're not seeing that after a refresh or some of the other features aren't working then let me know.
I would love if you could implement this script to programatically tag new Collections from a CSV list export from icheckmovies.com.
Premium users of ICM can export top lists and this script will parse that CSV file and create a collection and tag any films in your Plex library that appear in that list.
For example, I can export the top 500 Essential Cult Movies list (https://www.icheckmo...al cult movies/) and running the attached script I can create a collection called "500 Essential Cult Movies" and it will tag all the those movies that I own.
It would be the first step to then create a script that allows integrate tagging (Collections) from IMDB.com, Trakt.tv or Letterboxd.com lists.
This wouldn't be possible in a Javascript extension I'm afraid. As far as I know there's no way to tag movies from the Plex web API so that script modifies the metadata database directly.
WOOOOW !!
This has to be the greatest plugin ever! Thank you very much.
I didn't even know this existed, and the stats page is so awesome... a feature I always wanted.
Thank you again, really happy with this :)
As requested I’m posting my issue here (after initially logging it on the chrome web store)
Title: Doesn’t work on the plex.tv site since 1.1.0
“It used to work fine but the new version just results in the animated icon at the top as though it’s loading but never completes. I’ve tried various troubleshooting by setting the server address manually to no effect.
It does work of the local media manager OK but I’d rather use the plex.tv version as this is required for casting.”
I should expand that yes it does work using the local media manager but I don’t get the stats link on the main page now for some reason - The stats page does work if I go to it from the Chrome extension link. I’m not sure if this relevant but I thought I’d mention it anyway.
Pre-empting the request to run the debug option please see below the output from the chrome debug screen when launching http://plex.tv/web/app
Chrome Version 38.0.2125.111 m - up to date
Plex server version Version 0.9.9.14 - not quite up to date
Thanks for posting here. But I had to remove your log as it contained sensitive information. Could you please PM it to me instead? You can PM me by clicking on my username and looking for the send message button. Thanks.
Thanks for posting here. But I had to remove your log as it contained sensitive information..
Should he change his port # now? Everyone that is subscribed to this thread now has a copy of that information..... Not sure if that would help?
You need to remove the device from the list of devices in plex/web to revoke its token.
Is there a way to add your own folders to the dashboard?
as well as recommended, recently added, all, i would like to be able the add certain movies to individual folders for family members.
That way on the home screen they can click say Steve's Films, Suzanne's Films etc...
also like adding to a playlist you can add the movie to the family names collection.
advice please if it can be done
Sorry I posted the reply below direct to moussa but I should really have posted here just in case anyone else has a similar issue
Thanks, yes I have done this, and renewed my public IP after realising that I'd published it.
Now I have good news and bad.
The good news is that Transmogrify is now working properly. The bad news is that I'm not exactly sure what it was the problem but it was in response to moussa's suggestion to try accessing the site token link and the main plex.tv/web/app site using icognito tabs where everything worked perfectly, so I did the following:
1. disabled all extension except transmogrify and google cast
2. uninstalled about a dozen (win 7) applications that I no longer need or can do without (particularly recently installed applications)
3. thorough cleanup of win 7 (it was overdue anyway)
4. reset my chrome settings
5. restart
After this everything worked as expected (the only thing I don't have is the graph/stats link at the top of the page but I'm not worried about this feature)
I've also been able to re-enable all the chrome extensions that I had before and everything is still working great so make of that what you will.
Many thanks moussa for your help with this.
It sounds to me like you're describing a library that only contains certain movies. This would be very difficult to implement, and would require everyone involved to install the extension. Your best bet is just to create a new library and copy over the movies you want into a new folder monitored by that library.
5. restart
To clarify, sm1234 was getting a "Plex is down for maintenance" page when visting plex.tv/pms/servers instead of the expected servers xml the extension needs to function. It is likely that the 'reset my chrome settings' step fixed the issue, as it was probably a cache issue.
Sorry what i mean is why cannot i add sections to the home screen.
We have a choice of on deck, recently added, my library, playlists etc…
Can we not create and add our own sections?
And then like a playlist add movies to the new named sections by clicking and adding film titles to it
I would like to add two new sections
Steve’s Films
Suzanne’s Films
This way my girlfriends can just access her films and as she says not trapes through all my crap lol
Or add an option in the playlist to organise the playlist into a-z order?
