Transmogrify for Plex: A browser extension that adds features to Plex/Web
Just pushed out a tiny update (v0.7.1), that localizes air dates for missing seasons/episodes depending on your timezone.
Such a cool extension!  Wish I found this sooner!
I don't suppose the size of the IMDB/Rotten Tomatoes/etc. icons/info could be configurable?  On my laptop (which is not as high resolution as your monitor, from the screen shots) it feels a little cluttered.  Especially with the two ratings for RT.
Do you think you will have time to work a Safari extension ? :smiley:
Envoyé de mon iPad à l’aide de Tapatalk
I'm planning to work on dynamic resizing of the icons and logos.
Do you think you will have time to work a Safari extension ? :D
Envoyé de mon iPad à l'aide de Tapatalk
Unfortunately Apple has discontinued support for Safari on Windows so I wouldn't be able to develop and test it on Windows.
Does Plex Home Theatre allow for these kind of addons as well? if so do you have any plans on releasing an addon for the official home tether product in the future?
I've been trying to get use to the web interface but for my media centre use with remove controll and setup the Plex Home Theater app is allot better for our needs but I really do miss your trailer support, missing episodes, upcoming episodes, IMDB, RT rating..etc..etc... Fantastic features and thanks for your efforts and sharing this great web browser addon for Plex  :D
Is this supposed to work on Plex/Web local (since it got updated to 2.1)?
The addon gets enabled when you access your Plex media via the Plex website: http://plex.tv/web/app
* Don't worry it still all 'runs' and streams locally though
I know it still run my playback locally but I was just wondering if it could also work using the local client.
Thanks for the confirmation, just making sure it wasn't only me  ;)
I don't believe it does. It may have a plugin system but I very much doubt it would be flexible enough to let me implement all of the features.
I'm going to enable the extension for the local Plex/Web in an update once I carry out some testing.
Can I get some testers to check if the updated extension works for local Plex/Web:
Chrome version
Firefox version
Yeah, seems to work fine on local Plex/Web  :)
Chrome tested BTW
No go for me on Plex.  Now each time I start Chrome and access my local plex web I get prompted to log into myplex.
I've had that weird issue too, even though I'm already logged in. It's unrelated to my extension though.
do you enable the PMS option "require authentication on local network"? I don't that might be it...
I don't have that enabled and I'm signed in already, so I'm not sure why it keeps pestering me to log in.
Yes I do have that and I have had it set this way for many months.  I did not get the login prompt on my other computer that has not yet had the new extension installed.  I am going to try it now....
Same problem.  With the new extension enabled I get login prompt.  As soon as it is disabled I'm back to normal.
Tested on Chrome 34 on both Linux and Windows 7.
![post-57644-0-63571600-1398830725.png|690x331](upload://s9LGQbokTlMfy5ZXZRozFtwtUic.png)
Righto. Looks like I’ll need to do some further investigating
Okay I think I've fixed the issue. This required a large rewrite actually, because previously the extension heavily depended on plex.tv and its APIs. It should now be aware of whether it's running on a local plex/web or the hosted one.
Can I ask you to try the test extension I've just pushed out at https://chrome.google.com/webstore/detail/transmogrify-for-plex/ofkbaohocojojnignjdfmnbdlaoilkpn
I was prompted to login once.  After logging in everything in Plex Web seems to work.  I do not see any of the extras added by Transmogrify.
