"Turbocharge Your Metadata" popup won't close
Logging into the Plex server brings up a popup for which none of the buttons work, including the “Refresh all metadata” checkbox and the X to close it out. I’ve tried this on Firefox and Edge with the same results. Anyone know of a workaround?
Server Version#: 1.30.0.6486-629d58034
IIRC there’s a hidden pop-up underneath.
Try the escape key.
That did it. Thanks!
FYI, for anyone else running across this thread, here’s the reference:
