TV Series Matching and Language
Server Version#: 1.25.9.5721
Player Version#: any
I just saw the new feature for providing matching hints about TV Series (as described in Match Hinting for TV Series | Plex Support).
Is there a way to hint at the language it should use for matching? For example, though I watch many english language shows, I also watch some shows in German. The show and espisode description for those are usually either very bare-bones or missing so I tend to match the German shows with the language set to German. Could I achieve the same result by setting a ‘language:’ hint in the .plexmatch file for those shows?
BR,
Alex
Is my question / what I am trying to achieve not clear or isn’t there just anybody who’s able to answer it?
Sorry…
There’s sadly no way of hinting this
What you can do, is edit the show afterwards, and select the language you want.
Afterwards, refresh metadata for the show
That’s what I had been doing so far but the existance of the match hinting mechanism looks like the proper place to achieve this way easier and automatically to boot!
