Hi guys , cant find this question on here , has there been a problem with the amount of tv shows you can have on your server. up untill now i have not had a single problem , but the last two tv shows i added do not show up , both are exactly labeled like all the rest , the video format is the same. Is there a limit on total number of tv shows , This has happened after the last update, but i dont know if thats a coincidence.
ok have sorted it . it seems i had two full stops at the end of epispde number , sorry my bad.
