Greetings. When operating with the mainstream skin, RasPlex operates as expected. I would like to utilize the Confluence skin though as the family is more familiar with that skin from their previous XBMC experience. When I switch to that skin, the "TV Shows" and "Movies" menu selections that are normally available in XBMC, are not available from the main menu. Is this a limitation of the Confluence skin in RasPlex, or is some additional configuration required?
What PMS version are you running on?
The folders should be visible but will not contain your Plex content.
The skin needs to be modified to support Plex stuff like PMS sections, channels or your myPlex queue.
So, for the average user who is not a programmer, are you saying it won't work, or there are settings to make Movies and TV Shows show up? I'm having the same problem. Running Plex server 0.9.7.28.33 and Rasplex 0.9.9.7. I can usually fix anything that doesn't involve code but I can not figure this one out.
