TVDB DVD Order not naming episodes correctly
Server Version#: 1.21.3.4014
Player Version#:1.27.2.1599-7689068b
I’m trying to use the TVDB DVD order for Steven Universe and for season 3 - 5 it works great however seasons 1 & 2 aren’t being named correctly. Season 1 episodes are all named either ‘Steven Universe - Disc 1’ or ‘Steven Universe - Disc 2’ and season 2 episodes are all named ‘Steven Universe - Season 2’. I’m quite new to Plex so it might be something obvious I’ve missed but I can’t find a way to fix it without manually going through all 70+ episodes. Thanks :slight_smile:
The “Disc X” or “Season Y” references in the title imply this is taken from embedded metadata.
Your primary options are:
  1. remove the embedded metadata and re-add the episodes
  2. reorder the sources in the Settings > [Server Name] > AgentsTheTVDb configuration to prioritize TheTVDb.com over Local Media Assets (TV)
Thank you so much! That’s fixed it perfectly! :smiley:
