TvOS Live TV 404 error
Assuming a small bug but, i have live tv disabled in plex but it’s now showing as a menu option in the latest beta. If you click it it shows a 404 error.
404
“originalPath”: “/live-tv”
I see the same behavior. If you enable Live TV, it works, if you disable it, the tab still appears but displays 404.
Same here. The problem occurred with the latest beta. With the previous version everything was working as expected.
At least for me it was happening on the prior beta as well. And on iOS as well as tvOS.
