hi patrick thanks for the channel development i just posted a feature request in git hub which i hope you can work your magic on.
to include it in this conversation too, its to create an EPG which you can scroll through and also have the ability for recording upcoming shows. Having a recording function also built to have adhoc recording sessions started would be great too.
Hi Patrick just another update, recently PMS has been updated and now channels on IOS does not work connecting to tvheadend (it just mentions that it is due to networking errors). Thanks In addition i cant connect to it through plex client either now that the server is updated. not sure if the update has broken it but seems to have.
Hi is there anyway to disable transcoding. The TV can play the streams directly, but its getting transcoded for some reason and my server can’t keep up. I have tried direct play and direct stream options which don’t seem to make any difference. I have also tried renaming the transcoder files on the pled server, but the streams don’t play, I get content can’t be reached error.
hi guys I’m really struggling with getting this plugin to work. I have installed the channel within plex I’m struggling with the settings bit if anybody could help me? I don’t know what to put in the URL section http://localhost:9981/ doesn’t work!
Hi
I’m running Plex Versión 2.4.38, with Tvplexend channel shared, tvheadend clients for
KODI (pc), Kodi in Raspberry (openelec) working as a sharm in local (LAN) and remote (WAN) mode
But, I have another raspberry with Rasplex and the addon (Tvplexend channel) work’s ok in my LAN
and fail on the WAN.
Do you have some hints about this failure ?
I will appreciate any.
then i save it and restart plexmediaserver, when i try to edit config via web tvheadend gui in plex it shows the data already input and i can save it on the save button
it worked for a few hours, but now it keeps telling me all the time Channel is not responding…
so i checked the logs of the tvplexend and it gives me the following information
and now its giving me the following message
Aldo i can stream from another pc directly in TVheadend using VLC with user+pass login credentials requested on VLC
fine!
your code is better than tvheadend-ng more clear atless for me.
but have the same problem as tvheadend-ng for every client plex create a transcoding, it’s mean that if i ahve 4 users seeing de same channel my cpu is burning…
i want the same but that all the four users viewing the same channel use the same transcoding, it will be posible use transcoding feature of tvheadend and on plex only change the container mpegts to hls for example using same video codec and audio it will be fine or atless same video codec.
audio transcoding it isn’t so wasteful for cpu.
Thank you for your job!
I’m not a python developer but i’m good programer with java and I know a little bit about video transcoding
Is there any way we can disable the transcoding for live channels? SD channels are fine, but it cannot keep up with the HD channels, and there is a lot of stuttering.
Thanks!
