Server Version#: 1.41.6.9685
Player Version#: 1.70.1.303
Two mac minis, same server, same version of Plex HTPC.
One plays the VC1 file properly, the other will only work by transcoding.
How do I troubleshoot? Here are the info screens. The one that doesn’t work says “Application disabled direct play”
----below is the one that doesn’t play----
Enter the settings of the one that doesn’t play.
Compare them with the one that does play.
You may probably find something under
Settings - Plex for Mac - ‘Show Advanced’ - Debug
but look also on the “Quality” and “Player” tabs.
Thanks, I tried but could not find any differences. However, I updated to the next version of mac os (14.7.5 instead of 14.6.1) and this resolved the issue. For reference they are M2 Mac Minis.
