Two Suspect PlexAmp defects - feedback requested
Hi, I’m not sure if this is the correct place to post this. My apologies in advance if it is as I do not post nor use any message boards too frequently.
I wanted to report two suspected defects for PlexAmp. Is this the correct place to do so?
I have the latest PlexAmp running on Android 10 on my Pixel 4XL.
Suspect Defect #1:
When using Android Auto and one presses the ‘Right Next Track’ button on the last track, nothing occurs. In other audio applications that I’ve used, pressing the ‘next track’ button on the last track returns you to the first track on the current album or playlist. If the application is not designed to do this, should the application dither out the right track navigation button on the last track?
Suspect Defect #2:
While playing tracks in Android Auto, the cover art will occasionally flash between the current playing album and a previously played album cover art. This occurs mid-track.
confirm
Hi @karmadelic702,
Both these issues are known and are currently being tracked by the devs. Thanks for the report!
Thank you for the update. Appreciate your feedback.
