My portable hard drive which is plugged into my mac doesn’t show up when trying to add a library? All of movies are stored on this 2TB drive. What are the option for 800GB of movies that I don’t want on my working computer?
You don’t mention what macOS you are using but on the newer ones you have to specify that an application has access to either “Files & Folders” or “Full Disk Access” in the System Preferences/Settings. Plex won’t be able to access your drive until you give it permission from the OS. This may be why you can’t see the drive in Plex.
Good Luck,
Chris
Thanks Chris! Is this found in Plex? Sorry I am very new to this ![]()
I have the Big Sur 11.7.1
then it should look like top image in the MacOS system prefs
Oops I don’t see Plex at all in Full disk or Files and Folders
Then click on the + sign at the bottom of list. In the window that opens navigate to Plex Media Server, which should be in your Applications folder > click open to add it to the list.
That was it thank you so much!!
I was going to ask too can I include subtitles for movies?
