I am trying to configure the commands from my Harmony remote such that the ‘Guide’ button maps to the ‘Home’ functionality similar to pressing the ‘H’ key on the keyboard. I also want to enable shortcuts to skip to the next episode. I am using a RemotePi for my IR receiver.
I am starting with an updated lircd.conf file. I tried using the Philips device as outlined in the notes, but I was not able to send a command that generated home functionality. I then tried starting with the remote configured for MCE, but then used irrecord to detect the remote and program my mapping manually.
I ended up with a file with the following:
begin remote
name /storage/.config/lircd.conf
bits 13
flags RC6|CONST_LENGTH
eps 30
aeps 100
header 2667 872
one 464 424
zero 464 424
pre_data_bits 24
pre_data 0x1BFF83
gap 105909
toggle_bit_mask 0x8000
rc6_mask 0x100000000
begin codes
KEY_CONTEXT_MENU 0x1BDB
KEY_EXIT 0x1BDC
KEY_INFO 0x1BF0
KEY_HOME 0x1BD9
KEY_PAGEUP 0x1BED
KEY_PAGEDOWN 0x1BEC
KEY_UP 0x1BE1
KEY_DOWN 0x1BE0
KEY_LEFT 0x1BDF
KEY_RIGHT 0x1BDE
KEY_OK 0x1BDD
KEY_REWIND 0x1BEA
KEY_FORWARD 0x1BEB
KEY_PREVIOUS 0x1BE4
KEY_NEXT 0x1BE5
KEY_PLAY 0x1BE9
KEY_STOP 0x1BE6
KEY_PAUSE 0x1BE7
end codes
end remote
I programmed KEY_HOME based on the keypress when I hit ‘Guide’ and KEY_NEXT based on when I hit >>. However, what I see is that the keys for KEY_PAGEUP, KEY_UP and KEY_NEXT all behave the same, which is to skip to the next chapter (it seems) during playback instead of to the next episode. When I hit Guide it goes up one level similar to my programming for KEY_EXIT.
Should lircd.conf be all I need to apply custom settings for my configured buttons? Is there any way to tell in logs which key presses were received (and which KEY_XXX) mapping was executed? Do I also need a remote.xml or lircmap.xml? The how-to that used the Phillips DVD only configured lircd.conf.
Thanks for any assistance.
