Unknown decoder 'aac_lc' - when playing MKV from Roku
Server Version#: 1.23.2.4656
I have recently upgraded the plexserver on my Ubuntu server from 1.22.3.4523 to the newer 1.23.X.XXXX versions. I have tried each version as they come out with the version number 1.23.X but when playing MKV video files from a Roku I always get the following error.
[Transcoder] Unknown decoder 'aac_lc' in the logs.
If I revert back to the older 1.22.3.4523 version and the error stops and the video plays as normal. The error only shows when trying to access from a Roku device.
I like to keep my software up to date but this is preventing me from being able to update the plexserver.
Does anyone have some thoughts on how to address this. I have looked through older post related to this and tried it all, nothing seems to work.
Is anyone else having this issue? Even with the latest update the issue still exists.
  1. Stop Plex
  2. (presuming you run PMS as the default user plex)
  3. sudo chown -R plex:plex /var/lib/plexmediaserver
  4. Start Plex
  5. Try again.
  6. If still failing, Stop again
    a. Terminal session
    b. sudo bash
    c cd /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs
    d. rm -rf * (it will remove what is likely damaged)
    e. Restart
    f. It will require a few extra seconds to get each codec again (download) the first time it plays but the codec will be local after that.
I tried all of that and it didn’t help. I just installed 1.23.6.4881-e2e58f321 that was updated yesterday and it appears to have fixed the issue.
