There is one annoying “feature” in library handling. If plex movie matcher makes a false identification and load wrong information, when you unmatch it and it does not find on manual match yet correct info for the movie, I tend to write it in manually and check later if it can be found on database…
Problem is: when plex fist identifies it falsely,. it makes it permanently “matched”. So it cannot be seen in unmatched list (and it is almost impossible to check fast later which are actually unmatched and manually put in…).
Solution: WHEN user UNMATCH movie plex should mark it as UNMATCHED, so that it is seen on the category unmatched… this should be obvious and Plex have acted like this ages… please fix this.
