Unnecessary transcoding to Chromecast
Hi there
Because my Synology NAS is transcoding too slowly, I did a reencoding of an mkv based to target format that is specified on the Chromecast codec reference:
https://developers.google.com/cast/supported_media_types
Version of Media Server is 0.9.8.6
Input:
MKV with:
Stream #0.0: Video: h264 (High), yuv420p, 1280x720, PAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
Stream #0.1(ger): Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s (default)
So I did several tries in reencoding / remuxing the container and audio channel (I even tried MP3 encoding which is no option for me as it is only stereo):
/volume1/@appstore/MediaServer/bin/ffmpeg -i itn-dexter.s01e01.720p.mkv.back -vcodec copy -b:a 1600k -acodec libfaac -ac 6 dex.mp4
/volume1/@appstore/MediaServer/bin/ffmpeg -i itn-dexter.s01e01.720p.mkv.back -vcodec copy -b:a 1600k -acodec libfaac -profile:a aac_low -ac 6 dex.mp4
So at least the second remuxing to AAC with LC-AAC should fit. ffmpeg tells me now:
Stream #0.0(und): Video: h264 (High), yuv420p, 1280x720, 3753 kb/s, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
Stream #0.1(ger): Audio: aac, 48000 Hz, 5.1, s16, 197 kb/s
I renamed the file and reloaded the media library. Plex now shown me the correct information (sorry for german output, but I think you're quiet familiar with the shown information):
Medien
Video Auflösung 720p
Dauer 53:01
Bitrate 3957 kbps
Width 1280
Height 720
Seitenverhältnis 1.78
Container MP4
Video Bildfrequenz 24p
Optimized For Streaming No
Datei
Accessible Yes
Exists Yes
Dauer 53:01
Datei /volume1/Plex/Media/Serien/Dexter/S01/itn-dexter.s01e01.720p/itn-dexter.s01e01.mp4
Size 1.47 GB
Container MP4
Has 64bit Offsets 0
Video
Codec H264
Bitrate 3755 kbps
Bit Depth 8
CABAC 1
Chroma Subsampling 4:2:0
Color Space yuv
Dauer 53:01
Bildrate 23.976 fps
Frame Rate Mode vfr
Has Scaling Matrix 0
Height 720
Ebene 4.1
Profil high
Ref Frames 5
Scan Type progressive
Width 1280
Audio
Codec AAC
Kanäle 5.1
Bitrate 198 kbps
Sprache Deutsch
Bitratenmodus VBR
Dauer 53:01
Profil lc
Abtastfrequenz 48000 Hz
So I thought hooray, this should go trough, however the playback struggled all the time and my Synology NAS shown me 100% CPU usage with the new transcoder process running crazy (media indexing is NOT enabled).
The logs show me, that the media is getting transcoded:
Jan 11, 2014 16:00:31 [0xb192fb70] DEBUG - Using profile Chromecast
Jan 11, 2014 16:00:31 [0xb192fb70] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/20
Jan 11, 2014 16:00:31 [0xb192fb70] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/metadata/20
Jan 11, 2014 16:00:31 [0xb2856b70] DEBUG - Request: GET /library/metadata/20 [127.0.0.1:55598] (4 live)
Jan 11, 2014 16:00:31 [0xb2856b70] DEBUG - It took 0.000000 sec to serialize a list with 1 elements.
Jan 11, 2014 16:00:31 [0xb192fb70] INFO - Dexter - Dexter (S01E01): unable to obtain value for video.heigh
Jan 11, 2014 16:00:31 [0xb192fb70] DEBUG - Remuxing to dash/mp4/h264/aac
Jan 11, 2014 16:00:31 [0xb192fb70] DEBUG - Found session GUID of  in session start.
Jan 11, 2014 16:00:31 [0xb192fb70] DEBUG - Cleaning directory for session 4d062074-8ae5-4028-a1b8-ec603b13d501 (/volume1/Plex/tmp_transcoding/plex-transcode-4d062074-8ae5-4028-a1b8-ec603b13d501-027017d3-6561-4375-8c84-a615e06340a6)
Jan 11, 2014 16:00:31 [0xb192fb70] DEBUG - Starting a transcode session 4d062074-8ae5-4028-a1b8-ec603b13d501 at offset -1.0 (stopped=1)
Jan 11, 2014 16:00:31 [0xb192fb70] DEBUG - Job running: /volume1/@appstore/Plex Media Server/Resources/Plex New Transcoder -i http://127.0.0.1:32400/library/parts/115/file.mp4 -threads 0 -y -f dash -loglevel quiet -loglevel_plex error -map_metadata -1 -progressurl http://127.0.0.1:32400/video/:/transcode/session/4d062074-8ae5-4028-a1b8-ec603b13d501/progress -vcodec libx264 -crf 22 -maxrate 8000k -bufsize 16000k -vsi 0x0 -preset veryfast -x264opts cabac=0:me=dia:subme=0:me_range=4:no_chroma_me:8x8dct=0:bframes=0:rc_lookahead=1:qcomp=0.50:qpmin=10:qpmax=51:qpstep=4:partitions=none -min_segment_duration 3 -initial_segment 0 -force_key_frames expr:gte(t,n_forced*3) -map 0:0 -sn -acodec copy -map 0:1 dash
Jan 11, 2014 16:00:32 [0xb2e32b70] DEBUG - Request: GET /library/parts/115/file.mp4 [127.0.0.1:55599] (4 live)
Jan 11, 2014 16:00:32 [0xb2e32b70] DEBUG - Content-Length of /volume1/Plex/Media/Serien/Dexter/S01/itn-dexter.s01e01.720p/itn-dexter.s01e01.mp4 is 1573560188.
Jan 11, 2014 16:00:32 [0xb2e32b70] DEBUG - Request: GET /library/parts/115/file.mp4 [127.0.0.1:55600] (5 live)
Jan 11, 2014 16:00:32 [0xb2e32b70] DEBUG - Request range: 1571020993 to 0
Jan 11, 2014 16:00:32 [0xb2856b70] DEBUG - Request: GET /library/parts/115/file.mp4 [127.0.0.1:55601] (4 live)
Jan 11, 2014 16:00:32 [0xb2856b70] DEBUG - Request range: 48 to 0
Jan 11, 2014 16:00:32 [0xb2856b70] DEBUG - Content-Length of /volume1/Plex/Media/Serien/Dexter/S01/itn-dexter.s01e01.720p/itn-dexter.s01e01.mp4 is 1573560188.
Jan 11, 2014 16:00:32 [0xb2856b70] INFO - [Transcoder] Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'http://127.0.0.1:32400/library/parts/115/file.mp4':
Jan 11, 2014 16:00:32 [0xb2e32b70] INFO - [Transcoder]     Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1280x720, 3753 kb/s, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
Jan 11, 2014 16:00:32 [0xb2856b70] INFO - [Transcoder]     Stream #0:1(ger): Audio: aac (mp4a / 0x6134706D), 48000 Hz, 5.1, fltp, 197 kb/s
Jan 11, 2014 16:00:32 [0xb2e32b70] DEBUG - [Transcoder] Average FPS ~ 24 fps, Frame rate ~ 24 fps.
Jan 11, 2014 16:00:32 [0xb192fb70] DEBUG -  [FFMPEG] Duration: 3181
Jan 11, 2014 16:00:32 [0xb192fb70] DEBUG - Read line, and done: 1
Jan 11, 2014 16:00:32 [0xb192fb70] DEBUG - Started session successfully: 4d062074-8ae5-4028-a1b8-ec603b13d501
Jan 11, 2014 16:00:32 [0xb2856b70] INFO - [Transcoder] Output #0, dash, to 'dash':
Jan 11, 2014 16:00:32 [0xb2e32b70] INFO - [Transcoder]     Stream #0:0: Video: h264 ([33][0][0][0] / 0x0021), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=-1--1, 24k tbn, 23.98 tbc
Jan 11, 2014 16:00:32 [0xb192fb70] INFO - [Transcoder]     Stream #0:1: Audio: aac ([64][0][0][0] / 0x0040), 48000 Hz, 5.1, 197 kb/s
Jan 11, 2014 16:00:32 [0xb2856b70] DEBUG - Request: PUT /video/:/transcode/session/4d062074-8ae5-4028-a1b8-ec603b13d501/progress?width=1280&height=720 [127.0.0.1:55609] (5 live)
Jan 11, 2014 16:00:32 [0xb2856b70] DEBUG -  * width => 1280
Jan 11, 2014 16:00:32 [0xb2856b70] DEBUG -  * height => 720
Jan 11, 2014 16:00:32 [0xb2856b70] DEBUG - DASH segment range: -1 - -1
So my question is - what am I doing wrong? I think I have the correct container (MP4), the correct video (H264) and audio (AAC, LC-AAC) encodings. This should go trough without any transcoding?
Any help is very appreciated,
Joel
What client are you casting from? You should check your client's bitrate settings for local playback. I had to change my Android settings to "Maximum" for Over Local Network before casting to the Chromecast didn't transcode.
Hi Blatan
Thanks for your answer. The client was on iOS (iPhone). I just did a repackaging of the newest Plex Media Server for my DS214play and now it works like a charm. I think the profile wasn't set up properly and is fixed with the newest release (didn't find anything in the changelog so far).
Regards
Joel
