Server Version#: 1.15.6.1079
Player Version#: 2.34.0.983-edb7fbf7
Platform: Windows 10
When navigating the UNO interface in full screen TV mode with a remote control I have found that I can no longer operate the sidebar menu items and become stuck in certain circumstances. I have found this to occur when I perform the following steps from within a source that is not pinned to the sidebar.
To reproduce:
A. First unpin one or two items from the sidebar such as Podcasts or, in my case a Library called Documentaries from one of my servers.
Then:
- in UNO sidebar select MORE with a remote control
- expand the source such as Online Sources, or expand the server housing the library you unpinned.
- select the library which you have previously unpinned e.g. podcasts or ‘Documentaries’ (the sidebar disappears)
- navigate left to reopen the sidebar
- navigate to the top and select BACK
- The sidebar no longer works
To get the sidebar back you must navigate right (this may require several attempts) to select a media object and open its pre-play screen. Now you can exit back out of the pre-play screen and navigate left to the sidebar where you will see MORE is selected and you can navigate around the sidebar again.
