Unraid server not working for clients
Server Version#: 1.17.0.1841
Player Version#:used several on different platforms
I updated Unraid as well as the docker container for Plex and plex starts up fine, i can goto the web admin for plex and the players see the server exists it even lists the 2 channels i have “movies and TV” the movies randomly work but TV has just completely stopped loading when I try to open it and just says “There was an unexpected error loading this library”. ive verified all the docker IP settings and mount points are right, its as updated as it will let me set it. Im not really sure what else to change. Im really trying to avoid reinstalling the whole thing unless there is a way to backup the database as I use the watched/unwatched quite a bit and would rather not loose that.
i am having the exact same issue after upgrading. did you find a solution?
Did you try to optimize the database or running a metadata refresh on TV? Also post a log most likely you have a corrupted DB
