It doesn’t even complain about unsecure connection now, where it did the first time. I’ve set up plex twice now. Server works for a while, so i add my media and can even access it from a client. i come back after awhile and never turn the server off. The server has disappeared from my network and can’t even use the web gui when launched from unraid. No vpn, both are on ethernet, same network, plexinc repository. Any help?
Go to docker under unraid, open a console to the Plex container and get to the logs and post them here.
Accidentally posted this in the wrong thread a few minutes ago. Oops.
You may want to check for a corrupt database and repair it, if necessary:
https://support.plex.tv/articles/201100678-repair-a-corrupt-database/
Also, there appear to be some fairly common database corruption issues for users of Docker on Unraid. This is just one of several threads out there:
Yes there is a known issue with docker on Unraid if you are not on a cache drive.
Check for corruption and repair, check limetechs website for updates.
Ty for the help. No ever says thank you, so thank you again, ill look into it.
