Unusable update (3.109.2 for tizen 2.4.0)
My tizen app just got updated to 3.109.2 (the latest available), the UI isn’t just inconvenient it’s unusable most of the time.
Before this update this UI was able to be enabled or disabled from settings.
Is there is a way to downgrade?
Or maybe the devs taking back the option to go back for the old UI?
There’s no built-in option to downgrade in Plex unless you were using a beta version.
With official releases, what you see is what you get.
Have had a chance to take a look at these support articles?
https://support.plex.tv/articles/navigating-the-big-screen-apps/
https://support.plex.tv/articles/customizing-the-apps/
Also, there’s a bug I think where the new home screen comes up blank, if that’s happening to you, post back.
Thanks for replaying,
I didn’t see those support articles before and they explain what I’m missing, I can’t reach the “Manage Hubs”, and the sidebar doesn’t work most of the time.
I’ve tried reinstalling the app, and resetting my tv, same problems.
