Unwanted categories
I wonder if there is any way to remove categories from a libary. For example in my tv shows libary it automaticly added a category called newly added. Is there any way to remove this?
The “hubs” on the “Recommended” tab under a certain library cannot be customized.
This is only possible on the front page, where hubs from all libraries can be added and removed.
https://support.plex.tv/articles/customizing-the-mobile-apps-2
https://support.plex.tv/articles/customizing-the-apps
https://support.plex.tv/articles/customizing-plex-web
If you are using the Web app, make sure to tell your web browser that it shan’t discard the cookies of the domain plex.tv when you close it.
Otherwise most customizations will be reset after you close and re-open your web browser.
Thank you
