Update Error
Probably something very simple to fix but when i issue a 'git pull' for PlexConnect on my freeNAS server i get the following error. Anyone know how to fix as currently i delete the jail and do a fresh install which is a very long winded way to update.
root@PlexConnect:/PlexConnect # git pull
remote: Counting objects: 40, done.
remote: Compressing objects: 100% (30/30), done.
remote: Total 40 (delta 15), reused 24 (delta 10)
Unpacking objects: 100% (40/40), done.
From https://github.com/iBaa/PlexConnect
   ec6db32..0fd4b01  master     -> origin/master
Updating ec6db32..0fd4b01
error: Your local changes to the following files would be overwritten by merge:
        assets/js/updateXML.js
        assets/locales/plexconnect.pot
Please, commit your changes or stash them before you can merge.
Aborting
From the message it seems that you changed both updateXML.js and plexconnect.pot locally. Why?
The easiest might be to delete those files and try again...
Haven't changed either of those 2 files?
Just deleted and then it updated fine.
Thank you :)
