Updating PlexConnect - Error
can someone please help me with the following as I cant seem to get updated to the new version:
git pull
remote: Counting objects: 570, done.
remote: Compressing objects: 100% (307/307), done.
remote: Total 511 (delta 355), reused 344 (delta 199)
Receiving objects: 100% (511/511), 159.41 KiB | 281 KiB/s, done.
Resolving deltas: 100% (355/355), completed with 50 local objects.
 * [new branch]      master     -> origin/master
 * [new tag]         v0.1       -> v0.1
Your configuration specifies to merge with the ref 'XML_templates'
from the remote, but no such ref was fetched.
"XML_templates" was the branch name we used earlier. Since then it got fed back into "master", with XML_templates being removed. I guess this is your issue now...
Store your *.cfg files, delete that old stuff and git-pull the master branch from scratch.
Sorry not understanding what do I require to delete?  Can you advise me which files please?
everything in PlexConnect/... just keep the .cfg files for later.
