hi,
I downloaded the last version of PlexConnect, but when itty to update in terminal with git pull, i get this message:
Last login: Mon Feb 17 23:48:27 on ttys002
ives-macmini:PlexConnect-master iveflammang$ git pull
fatal: Not a git repository (or any of the parent directories): .git
any ideas?
thx
How do i see witch version of PlexConnect i have? to know when i have to update:)
You need to clone the git before you can git pull. Instructions are in the readme.md here:
https://github.com/iBaa/PlexConnect
Openconnect and webconnect in my signature can do update plexconnect also after you clone the git assuming your on OSX which I thought you said you were prior.
I know but i can t get it to work. Thats why i use plexify
What’s the issue preventing openconnect from working?
*Edit - plexconnect was located in the hidden library folder ~/library which prevented OpenConnect from working. Plexconnect also was not cloned per the readme.md. Once plexconnect was located in a non-hidden folder and cloned properly OpenConnect and plexconnect work perfectly using git pull, openconnect or webconnect to update the code. Mark as solved if needed/desired.
