Hi all,
I’ve been using a third gen Fire TV to direct play media from my desktop, mainly 1080p MKV. I have hard wired ethernet throughout my home so it works great, apart from the fact that 5.1 audio tracks only play in Stereo unless I go into the Fire TV audio settings, disable Dolby Digital Plus and enable Dolby Digital - despite passthrough to my amp which can decode pretty much any format audio being enabled.
I’m tired of switching back and forth between these settings every time I want to use the Fire TV to stream Netflix or Amazon Video, so I’m looking at buying a new streaming device that won’t have these issues with 5.1 audio.
Everyone seems to recommend the Nvidia Shield - but the 2019 model is available as the Shield TV (tube shaped device) and the Shield TV Pro. As I’m not looking to use the device as a server, do I need the Pro for the setup I have described above or will the Shield TV be ok?
Many thanks,
Guy
