Hi, is there any USB IR adapter that work ot of the box with rasplex and a logitech Harmoney?
Maybe anyone got a amazon or ebay link from?
It should be possible to use every USB receiver which is supported by LIRC.
Take a look at OpenELEC/XBMC and any other Linux-HTPC project wiki - probably there is a list of supported receivers.
(Take a look at the GPIO-Receiver solution too (wiki, forum). It requires some technical knowledge and work but it's cheap and works fine)
I'm using a logitech with no problems
ttp://forums.plexapp.com/index.php/topic/63334-logitec-harmony-remote-support/?p=371053
