'Use Custom Preset' is broken?
Okay so in trying out new and updated presets in the Equalizer settings I managed to break the toggle button for ‘Use Custom Preset’.
Each time I tried to toggle it back on it would stubbornly decline my effort. See gif and I’ve uploaded my zip debugging file.
I’ve also forced quit PlexAmp, reopened it and still had the toggle switch be problematic on return. :man_shrugging:t2: unsure what’s happening.
20240404_023629
1325339873046244.zip (131.5 KB)
Did you select a preset below (with “Search Presets”)?
Flipping this switch will only have a visual change after you did so.
Are you able to select a different preset?
Do you remember which profile you tried last?
