Verify Plexconnect is installed correctly
Is there a command you can write in SSH to verify that PlexConnect is installed correctly on your ATV2??
Many thanks
launchctl list | grep plexconnect
Should result in a line like...
  -   com.plex.plexconnect.bash.plist
Your really should read the "readme.txt". You did, didn't you?
Thanks,
Yeah I did but finding it difficult to understand if I'm honest
When I SSH launchctl list | grep plexconnect
I get
-       0       com.plex.plexconnect.bash
So I take it Plexconnect is not installed correctly??
Well, it says it had an issue starting up...
Go through the read me/debug stuff and re-create the log file. You should find a PlexConnect.log afterwards, hopefully giving some hints to the root cause.
