Very Bad transcoding Qualiy Ubuntu 16.04 100% CPU load
Server Version#: 1.13.5.5332-21ab172de
Player Version#: 3.67.1
I just switched from a Intel X3440 Server (running on ubuntu 14.04 to a E-1230 server (running on ubuntu 16.04 and ever since, watchable transcoding is not possible. Loads of artifacts and stuttering + 100% CPU load. Hope somebody can help.
Heres some logs:
Sep 12, 2018 16:39:12.396 [0x7fc9a13fe700] INFO - Plex Media Server v1.13.5.5332-21ab172de - Docker Docker Container x86_64 - build: linux-ubuntu-x86_64 ubuntu - GMT 02:00
Sep 12, 2018 16:39:12.396 [0x7fc9a13fe700] INFO - Linux version: 4.15.0-34-generic (#37~16.04.1-Ubuntu SMP Tue Aug 28 10:44:06 UTC 2018), language: C
Sep 12, 2018 16:39:12.396 [0x7fc9a13fe700] INFO - Processor           Intel(R) Xeon(R) CPU E31230 @ 3.20GHz
Sep 12, 2018 16:39:12.396 [0x7fc9a13fe700] INFO - /usr/lib/plexmediaserver/Plex Media Server
Sep 12, 2018 17:33:25.934 [0x7fc98f7ff700] DEBUG - It took 10.000000 ms to retrieve 124 items.
Sep 12, 2018 17:33:25.936 [0x7fc98f7ff700] DEBUG - We're going to try to auto-select an audio stream for account 1.
Sep 12, 2018 17:33:25.936 [0x7fc98f7ff700] DEBUG - Selecting best audio stream for part ID 239 (autoselect: 1 language: en)
Sep 12, 2018 17:33:25.936 [0x7fc98f7ff700] DEBUG - We're going to try to auto-select a subtitle.
Sep 12, 2018 17:33:25.936 [0x7fc98f7ff700] DEBUG - Found a suitable native subtitle language [eng] for a foreign film
Sep 12, 2018 17:33:25.936 [0x7fc98f7ff700] DEBUG - Audio Stream: 1981, Subtitle Stream: 1983
Sep 12, 2018 17:33:25.939 [0x7fc98f7ff700] DEBUG - MDE: Selected protocol http; container: mkv
Sep 12, 2018 17:33:25.939 [0x7fc98f7ff700] DEBUG - MDE: analyzing media item 239
Sep 12, 2018 17:33:25.939 [0x7fc98f7ff700] DEBUG - MDE: Ocean's Eight (2018): Direct Play is disabled
Sep 12, 2018 17:33:25.939 [0x7fc98f7ff700] DEBUG - MDE: Ocean's Eight (2018): no direct play video profile exists for http/mkv/h264
Sep 12, 2018 17:33:25.939 [0x7fc98f7ff700] DEBUG - MDE: Ocean's Eight (2018): no direct play video profile exists for http/mkv/h264/truehd
Sep 12, 2018 17:33:25.939 [0x7fc98f7ff700] DEBUG - MDE: Ocean's Eight (2018): no direct play video profile exists for http/mkv/h264/ac3
Sep 12, 2018 17:33:25.939 [0x7fc98f7ff700] DEBUG - MDE: Ocean's Eight (2018): selected media 0 / 239
Sep 12, 2018 17:33:25.939 [0x7fc98f7ff700] DEBUG - Streaming Resource: Calculated bandwidth of 10500000kbps exceeds bandwidth limit. Changing decision parameters provided by client to fit bandwidth limit of 8000kbps
Sep 12, 2018 17:33:25.939 [0x7fc98f7ff700] DEBUG - Streaming Resource: Determining preferred transcode encoders through transcode only decision.
Sep 12, 2018 17:33:25.940 [0x7fc98f7ff700] DEBUG - Codecs: testing h264_nvenc (encoder)
Sep 12, 2018 17:33:25.940 [0x7fc98f7ff700] ERROR - [FFMPEG] - Cannot load libcuda.so.1
Sep 12, 2018 17:33:25.940 [0x7fc98f7ff700] WARN - avcodec_open2 returned -1313558101 for encoder 'h264_nvenc'
Sep 12, 2018 17:33:25.940 [0x7fc98f7ff700] DEBUG - Codecs: hardware transcoding: testing API vaapi
Sep 12, 2018 17:33:25.940 [0x7fc98f7ff700] ERROR - [FFMPEG] - No VA display found for device: /dev/dri/renderD128.
Sep 12, 2018 17:33:25.940 [0x7fc98f7ff700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Invalid argument
Sep 12, 2018 17:33:25.940 [0x7fc98f7ff700] DEBUG - Scaled up video bitrate to 39117Kbps based on 1.500000x fudge factor.
Sep 12, 2018 17:33:25.941 [0x7fc98f7ff700] DEBUG - Codecs: hardware transcoding: testing API vaapi
Sep 12, 2018 17:33:25.941 [0x7fc98f7ff700] ERROR - [FFMPEG] - No VA display found for device: /dev/dri/renderD128.
Sep 12, 2018 17:33:25.941 [0x7fc98f7ff700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Invalid argument
Sep 12, 2018 17:33:25.941 [0x7fc98f7ff700] DEBUG - Scaled up video bitrate to 39117Kbps based on 1.500000x fudge factor.
Sep 12, 2018 17:33:25.941 [0x7fc98f7ff700] DEBUG - Streaming Resource: Reducing playback quality for 7619kbps stream bitrate: video resolution to 1920x1080, audio channels to 8, quality to 6, disable video DS as 2147483647kbps is > the 7100kbps available, disable audio DS as 2147483647kbps is > the 424kbps available
Sep 12, 2018 17:33:25.941 [0x7fc98f7ff700] DEBUG - Codecs: testing h264_nvenc (encoder)
Sep 12, 2018 17:33:25.941 [0x7fc98f7ff700] ERROR - [FFMPEG] - Cannot load libcuda.so.1
Sep 12, 2018 17:33:25.941 [0x7fc98f7ff700] WARN - avcodec_open2 returned -1313558101 for encoder 'h264_nvenc'
Sep 12, 2018 17:33:25.941 [0x7fc98f7ff700] DEBUG - MDE: Selected protocol http; container: mkv
Sep 12, 2018 17:33:25.941 [0x7fc98f7ff700] DEBUG - MDE: analyzing media item 239
Sep 12, 2018 17:33:25.942 [0x7fc98f7ff700] DEBUG - MDE: Ocean's Eight (2018): Direct Play is disabled
Sep 12, 2018 17:33:25.942 [0x7fc98f7ff700] DEBUG - MDE: Ocean's Eight (2018): no direct play video profile exists for http/mkv/h264
Sep 12, 2018 17:33:25.942 [0x7fc98f7ff700] DEBUG - MDE: Ocean's Eight (2018): no direct play video profile exists for http/mkv/h264/truehd
Sep 12, 2018 17:33:25.942 [0x7fc98f7ff700] DEBUG - MDE: Ocean's Eight (2018): no direct play video profile exists for http/mkv/h264/ac3
Sep 12, 2018 17:33:25.942 [0x7fc98f7ff700] DEBUG - Ocean's Eight - video.bitrate limitation applies: 26078 > 7100
Sep 12, 2018 17:33:25.942 [0x7fc98f7ff700] DEBUG - MDE: Ocean's Eight (2018): Direct Streaming is disabled, so video stream will be transcoded
Sep 12, 2018 17:33:25.942 [0x7fc98f7ff700] DEBUG - MDE: Ocean's Eight (2018): no remuxable profile found, so video stream will be transcoded
Sep 12, 2018 17:33:25.942 [0x7fc98f7ff700] DEBUG - Codecs: testing h264_nvenc (encoder)
Sep 12, 2018 17:33:25.942 [0x7fc98f7ff700] ERROR - [FFMPEG] - Cannot load libcuda.so.1
Sep 12, 2018 17:33:25.942 [0x7fc98f7ff700] WARN - avcodec_open2 returned -1313558101 for encoder 'h264_nvenc'
Sep 12, 2018 17:33:25.942 [0x7fc98f7ff700] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
Sep 12, 2018 17:33:25.942 [0x7fc98f7ff700] DEBUG - Codecs: hardware transcoding: testing API vaapi
Sep 12, 2018 17:33:25.942 [0x7fc98f7ff700] ERROR - [FFMPEG] - No VA display found for device: /dev/dri/renderD128.
Sep 12, 2018 17:33:25.942 [0x7fc98f7ff700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Invalid argument
Sep 12, 2018 17:33:25.942 [0x7fc98f7ff700] DEBUG - Scaled up video bitrate to 39117Kbps based on 1.500000x fudge factor.
Sep 12, 2018 17:33:25.942 [0x7fc98f7ff700] DEBUG - MDE: Ocean's Eight (2018): Audio Direct Streaming is disabled, so video's audio stream will be transcoded
Sep 12, 2018 17:33:25.942 [0x7fc98f7ff700] DEBUG - MDE: Cannot direct stream audio stream due to profile or setting limitations
Sep 12, 2018 17:33:25.942 [0x7fc98f7ff700] DEBUG - MDE: Ocean's Eight (2018): selected media 0 / 239
Sep 12, 2018 17:33:25.942 [0x7fc98f7ff700] DEBUG - Streaming Resource: Session 0x7fc98e167560:1mvvdtuk02m1k1lwsviiorbe changed from using 56108kbps to 7902kbps of WAN bandwidth.  Used bandwidth is now 7902kbps
Sep 12, 2018 17:33:25.942 [0x7fc98f7ff700] DEBUG - Streaming Resource: Session 0x7fc98e167560:1mvvdtuk02m1k1lwsviiorbe changed transcode slot usage to used.  Used slots is now 1
Sep 12, 2018 17:33:25.942 [0x7fc98f7ff700] DEBUG - Streaming Resource: Reached Decision id=239 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=239 part=(id=239 decision=transcode container=mkv protocol=http streams=(Video=(id=1980 decision=transcode bitrate=7100 encoder=libx264 width=1920 height=1080) Audio=(id=1981 decision=transcode bitrate=424 encoder=libopus channels=8 rate=48000) Subtitle=(id=1983 decision=transcode bitrate=2147483647 encoder=dvdsub languageCode=eng location=embedded))))
Sep 12, 2018 17:33:25.945 [0x7fc99ebff700] DEBUG - Completed: [62.216.207.90:26125] 200 GET /video/:/transcode/universal/decision?hasMDE=1&path=%2Flibrary%2Fmetadata%2F239&mediaIndex=0&partIndex=0&protocol=http&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=wan&maxVideoBitrate=8000&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&session=8sv5la2vhj1w81zlb5brfi52&offset=263&subtitles=auto&copyts=1&Accept-Language=en (10 live) TLS GZIP 26ms 5632 bytes (pipelined: 12)
Sep 12, 2018 17:33:26.234 [0x7fc99ebff700] DEBUG - Auth: authenticated user 1 as .Marcel.
Sep 12, 2018 17:33:26.234 [0x7fc9767ff700] DEBUG - Request: [62.216.207.90:10709 (WAN)] GET /video/:/transcode/universal/start?hasMDE=1&path=%2Flibrary%2Fmetadata%2F239&mediaIndex=0&partIndex=0&protocol=http&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=wan&maxVideoBitrate=8000&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&session=8sv5la2vhj1w81zlb5brfi52&offset=263&subtitles=auto&copyts=1&Accept-Language=en (11 live) TLS Signed-in Token (.Marcel.)
Sep 12, 2018 17:33:26.234 [0x7fc9767ff700] DEBUG - Found session GUID of 8sv5la2vhj1w81zlb5brfi52 in session start.
Sep 12, 2018 17:33:26.235 [0x7fc9767ff700] DEBUG - TranscodeUniversalRequest: using augmented profile Konvergo
Sep 12, 2018 17:33:26.235 [0x7fc9767ff700] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/239?checkFiles=1&includeBandwidths=1&offset=263&X-Plex-Client-Capabilities=protocols%3Dshoutcast%2Chttp-video;videoDecoders%3Dh264{profile%3Ahigh%26resolution%3A2160%26level%3A52};audioDecoders%3Dmp3%2Caac%2Cdts{bitrate%3A800000%26channels%3A2}%2Cac3{bitrate%3A800000%26channels%3A2}&X-Plex-Session-Identifier=1mvvdtuk02m1k1lwsviiorbe
Sep 12, 2018 17:33:26.236 [0x7fc9767ff700] DEBUG - Auth: authenticated user 1 as .Marcel.
Sep 12, 2018 17:33:26.248 [0x7fc9767ff700] DEBUG - It took 10.000000 ms to retrieve 124 items.
Sep 12, 2018 17:33:26.251 [0x7fc9767ff700] DEBUG - We're going to try to auto-select an audio stream for account 1.
Sep 12, 2018 17:33:26.251 [0x7fc9767ff700] DEBUG - Selecting best audio stream for part ID 239 (autoselect: 1 language: en)
Sep 12, 2018 17:33:26.251 [0x7fc9767ff700] DEBUG - We're going to try to auto-select a subtitle.
Sep 12, 2018 17:33:26.252 [0x7fc9767ff700] DEBUG - Found a suitable native subtitle language [eng] for a foreign film
Sep 12, 2018 17:33:26.252 [0x7fc9767ff700] DEBUG - Audio Stream: 1981, Subtitle Stream: 1983
Sep 12, 2018 17:33:26.255 [0x7fc9767ff700] DEBUG - Cleaning directory for session 8sv5la2vhj1w81zlb5brfi52 ()
Sep 12, 2018 17:33:26.255 [0x7fc9767ff700] DEBUG - Starting a transcode session 8sv5la2vhj1w81zlb5brfi52 at offset -1.0 (state=3)
Sep 12, 2018 17:33:26.256 [0x7fc9767ff700] DEBUG - TPU: hardware transcoding: enabled, but no hardware decode accelerator found
Sep 12, 2018 17:33:26.256 [0x7fc9767ff700] DEBUG - [Universal] Using local file path instead of URL: /yourcomputer/mnt/deluge/downloaded/PlexMedia/Movies/HD/Ocean's 8 (2018)/Oceans.Eight.2018.BluRay.1080p.TrueHD.Atmos.7.1.AVC.REMUX-FraMeSToR.mkv
Sep 12, 2018 17:33:26.256 [0x7fc9767ff700] DEBUG - TPU: hardware transcoding: zero-copy support not present
Sep 12, 2018 17:33:26.257 [0x7fc9767ff700] DEBUG - TPU: hardware transcoding: final decoder: , final encoder:
Sep 12, 2018 17:33:26.257 [0x7fc9767ff700] DEBUG - Job running: EAE_ROOT='/tmp/pms-ef9d4d99-5ece-4c1e-9135-be7bb448c3fa/EasyAudioEncoder' FFMPEG_EXTERNAL_LIBS='/config/Library/Application\ Support/Plex\ Media\ Server/Codecs/e944d3a-1322-linux-ubuntu-x86_64/' XDG_CACHE_HOME='/config/Library/Application Support/Plex Media Server/Cache' XDG_DATA_HOME='/usr/lib/plexmediaserver/Resources' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/usr/lib/plexmediaserver/Plex Transcoder' '-codec:0' 'h264' '-codec:1' 'truehd_eae' '-eae_prefix:1' '8sv5la2vhj1w81zlb5brfi52_' '-ss' '263' '-i' '/yourcomputer/mnt/deluge/downloaded/PlexMedia/Movies/HD/Ocean'\''s 8 (2018)/Oceans.Eight.2018.BluRay.1080p.TrueHD.Atmos.7.1.AVC.REMUX-FraMeSToR.mkv' '-filter_complex' '[0:0]scale=w=1920:h=1080[0];[0]format=pix_fmts=yuv420p|nv12[1]' '-filter_complex' '[0:1] aresample=async=1:ocl='\''7.1'\'':osr=48000[2]' '-map' '[1]' '-codec:0' 'libx264' '-crf:0' '24' '-maxrate:0' '7100k' '-bufsize:0' '14200k' '-r:0' '23.975999999999999' '-preset:0' 'veryfast' '-x264opts:0' 'subme=0:me_range=4:rc_lookahead=10:me=hex:8x8dct=0:partitions=none' '-map' '[2]' '-metadata:s:1' 'language=eng' '-codec:1' 'libopus' '-b:1' '424k' '-map' '0:3' '-metadata:s:2' 'language=eng' '-codec:2' 'dvdsub' '-map' '0:t?' '-codec:t' 'copy' '-f' 'segment' '-segment_format' 'matroska' '-segment_format_options' 'live=1' '-segment_time' '1' '-segment_header_filename' 'header' '-segment_start_number' '0' '-segment_list' 'http://127.0.0.1:32400/video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/seglist' '-segment_list_type' 'csv' '-segment_list_size' '2147483647' '-segment_list_separate_stream_times' '1' '-avoid_negative_ts' 'disabled' '-map_metadata:g' '-1' '-map_metadata:c' '-1' '-map_chapters' '-1' 'chunk-%05d' '-start_at_zero' '-copyts' '-y' '-nostats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/progress'
Sep 12, 2018 17:33:26.259 [0x7fc9767ff700] DEBUG - Jobs: Starting child process with pid 4127
Sep 12, 2018 17:33:26.287 [0x7fc9777fe700] DEBUG - Request: [127.0.0.1:54050 (Loopback)] PUT /video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/progress/stream?index=0&id=0&codec=h264&type=video (12 live) Signed-in Token (.Marcel.)
Sep 12, 2018 17:33:26.288 [0x7fc99ebff700] DEBUG - Completed: [127.0.0.1:54050] 206 PUT /video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/progress/stream?index=0&id=0&codec=h264&type=video (12 live) 0ms 227 bytes (range: bytes=0-)
Sep 12, 2018 17:33:26.288 [0x7fc996bfe700] DEBUG - Request: [127.0.0.1:54052 (Loopback)] PUT /video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/progress/stream?index=1&id=0&codec=truehd&type=audio (13 live) Signed-in Token (.Marcel.)
Sep 12, 2018 17:33:26.289 [0x7fc99ebff700] DEBUG - Completed: [127.0.0.1:54052] 206 PUT /video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/progress/stream?index=1&id=0&codec=truehd&type=audio (13 live) 0ms 227 bytes (range: bytes=0-)
Sep 12, 2018 17:33:26.290 [0x7fc9853fe700] DEBUG - Request: [127.0.0.1:54054 (Loopback)] PUT /video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/progress/stream?index=2&id=0&codec=ac3&type=audio (14 live) Signed-in Token (.Marcel.)
Sep 12, 2018 17:33:26.290 [0x7fc99ebff700] DEBUG - Completed: [127.0.0.1:54054] 206 PUT /video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/progress/stream?index=2&id=0&codec=ac3&type=audio (14 live) 0ms 227 bytes (range: bytes=0-)
Sep 12, 2018 17:33:26.399 [0x7fc98f7ff700] DEBUG - Request: [127.0.0.1:54056 (Loopback)] PUT /video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/progress/streamDetail?index=0&id=0&codec=h264&type=video&profile=High&width=1920&height=1080&interlaced=0&sar=1:1&level=41&frameRate=23.976&disp_default=1 (14 live) Signed-in Token (.Marcel.)
Sep 12, 2018 17:33:26.400 [0x7fc99ebff700] DEBUG - Completed: [127.0.0.1:54056] 206 PUT /video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/progress/streamDetail?index=0&id=0&codec=h264&type=video&profile=High&width=1920&height=1080&interlaced=0&sar=1:1&level=41&frameRate=23.976&disp_default=1 (14 live) 0ms 227 bytes (range: bytes=0-)
Sep 12, 2018 17:33:26.400 [0x7fc9777fe700] DEBUG - Request: [127.0.0.1:54058 (Loopback)] PUT /video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/progress/streamDetail?index=1&id=0&codec=truehd&type=audio&language=eng&channels=8&layout=7.1&sampleRate=48000&bitDepth=24&disp_default=1 (15 live) Signed-in Token (.Marcel.)
Sep 12, 2018 17:33:26.400 [0x7fc99ebff700] DEBUG - Completed: [127.0.0.1:54058] 206 PUT /video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/progress/streamDetail?index=1&id=0&codec=truehd&type=audio&language=eng&channels=8&layout=7.1&sampleRate=48000&bitDepth=24&disp_default=1 (14 live) 0ms 227 bytes (range: bytes=0-)
Sep 12, 2018 17:33:26.401 [0x7fc996bfe700] DEBUG - Request: [127.0.0.1:54060 (Loopback)] PUT /video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/progress/streamDetail?index=2&id=0&codec=ac3&type=audio&bitrate=640000&language=eng&channels=6&layout=5.1%28side%29&sampleRate=48000 (14 live) Signed-in Token (.Marcel.)
Sep 12, 2018 17:33:26.401 [0x7fc99e3fe700] DEBUG - Completed: [127.0.0.1:54060] 206 PUT /video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/progress/streamDetail?index=2&id=0&codec=ac3&type=audio&bitrate=640000&language=eng&channels=6&layout=5.1%28side%29&sampleRate=48000 (14 live) 0ms 227 bytes (range: bytes=0-)
Sep 12, 2018 17:33:26.402 [0x7fc9853fe700] DEBUG - Request: [127.0.0.1:54062 (Loopback)] PUT /video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/progress/streamDetail?index=3&id=0&codec=hdmv_pgs_subtitle&type=subtitle&language=eng (14 live) Signed-in Token (.Marcel.)
Sep 12, 2018 17:33:26.402 [0x7fc99e3fe700] DEBUG - Completed: [127.0.0.1:54062] 206 PUT /video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/progress/streamDetail?index=3&id=0&codec=hdmv_pgs_subtitle&type=subtitle&language=eng (14 live) 0ms 227 bytes (range: bytes=0-)
Sep 12, 2018 17:33:26.403 [0x7fc98f7ff700] DEBUG - Request: [127.0.0.1:54064 (Loopback)] PUT /video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/progress/streamDetail?index=4&id=0&codec=hdmv_pgs_subtitle&type=subtitle&language=fre (14 live) Signed-in Token (.Marcel.)
Sep 12, 2018 17:33:26.403 [0x7fc99e3fe700] DEBUG - Completed: [127.0.0.1:54064] 206 PUT /video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/progress/streamDetail?index=4&id=0&codec=hdmv_pgs_subtitle&type=subtitle&language=fre (14 live) 0ms 227 bytes (range: bytes=0-)
Sep 12, 2018 17:33:26.404 [0x7fc9777fe700] DEBUG - Request: [127.0.0.1:54066 (Loopback)] PUT /video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/progress/streamDetail?index=5&id=0&codec=hdmv_pgs_subtitle&type=subtitle&language=por (15 live) Signed-in Token (.Marcel.)
Sep 12, 2018 17:33:26.404 [0x7fc99e3fe700] DEBUG - Completed: [127.0.0.1:54066] 206 PUT /video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/progress/streamDetail?index=5&id=0&codec=hdmv_pgs_subtitle&type=subtitle&language=por (14 live) 0ms 227 bytes (range: bytes=0-)
Sep 12, 2018 17:33:26.405 [0x7fc996bfe700] DEBUG - Request: [127.0.0.1:54068 (Loopback)] PUT /video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/progress/streamDetail?index=6&id=0&codec=hdmv_pgs_subtitle&type=subtitle&language=spa (14 live) Signed-in Token (.Marcel.)
Sep 12, 2018 17:33:26.405 [0x7fc99e3fe700] DEBUG - Completed: [127.0.0.1:54068] 206 PUT /video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/progress/streamDetail?index=6&id=0&codec=hdmv_pgs_subtitle&type=subtitle&language=spa (14 live) 0ms 227 bytes (range: bytes=0-)
Sep 12, 2018 17:33:26.423 [0x7fc9853fe700] DEBUG - Request: [127.0.0.1:54070 (Loopback)] PUT /video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/progress?duration=6609.686000 (15 live) Signed-in Token (.Marcel.)
Sep 12, 2018 17:33:26.423 [0x7fc9767ff700] DEBUG - Started session successfully: 8sv5la2vhj1w81zlb5brfi52
Sep 12, 2018 17:33:26.424 [0x7fc99ebff700] DEBUG - Completed: [127.0.0.1:54070] 206 PUT /video/:/transcode/session/8sv5la2vhj1w81zlb5brfi52/22e28d1b-c286-498d-8d68-d913b814945c/progress?duration=6609.686000 (14 live) 1ms 326 bytes (range: bytes=0-)
Sep 12, 2018 17:33:26.473 [0x7fc99ebff700] DEBUG - Auth: authenticated user 1 as .Marcel.
I need:
  1. XML of the video file being played
  2. Playback settings in the client
  3. DEBUG only log files captured 30 seconds after recreating the problem.
    (Settings - Server - Help - Download Logs)
With these, I can look at what’s happening.
XML: XML.zip (5.7 KB)
  1. Playback settings in the client:
And the DEBUG log: Plex Media Server.log (2.6 MB)
Its not specific to one File, all of the have the same issue. The weird this is on the less powerful Intel X3440 i could have 4-5 simultaneus 1080p transcodes.
PGS subtitles are always the hardest. They are a single-threaded operation.
Please enable transcoder DEBUG logging as well. I would like the see its reported progress.
curl 'http://ip.addr.of.server:32400/:/prefs/set?TranscoderLogLevel=debug&X-Plex-Token=your-plex-online-token-from-Preferences.xml'
In your next reply, please grab the entire ZIP as requested.
Ok here’s the complete Log Zip: Plex Media Server Logs_2018-09-12_20-16-42.zip (2.8 MB)
I havent noticed PGS subtitles are enabled since none were displayed.
On my other server It automatically selects the srt subtitles and thats why I havent noticed any PGS problems I guess.
Also this time I got an transcoding error and the stream stopped.
I did not realize this is Docker.
I cannot help you with Docker. I’m sorry.
I will move this to the Docker forum where someone there can assist further.
Sep 12, 2018 19:59:14.448 [0x7fc9a13fe700] INFO - Plex Media Server v1.13.5.5332-21ab172de - Docker Docker Container x86_64 - build: linux-ubuntu-x86_64 ubuntu - GMT 02:00
Sep 12, 2018 19:59:14.449 [0x7fc9a13fe700] INFO - Linux version: 4.15.0-34-generic (#37~16.04.1-Ubuntu SMP Tue Aug 28 10:44:06 UTC 2018), language: C
If I may make a suggestion, If you’re running Linux on the host, you will get better performance with equal library portability
Sorry to thread jack… what is this equal library portability you speak of?
https://forums.plex.tv/t/back-up-restore-clone-your-pms-metadata
tar or zip, you choice
So now every stream cancells after exactly one minute with the following message: “Conversion failed. The transcoder exited due to an error.”
I think it didnt happen before I did curl ‘http://ip.addr.of.server:32400/:/prefs/set?TranscoderLogLevel=debug&X-Plex-Token=your-plex-online-token-from-Preferences.xml
how can I undo it?
