Very hight CPU usage from Plex and no access to Plex parameters (Odroid HC2 / OMV5)
Hello,
I installed Plex on Docker (using Docker compose on Portainer) on my NAS (Odroid HC2) which is running on OMV 5.
My first problem is that Plex is using all CPU capacities. When Plex is runing the CPU usage go up to 90-95%. Even if i’m not streaming any media.
My second problem is that the browser player doesn’t find my Plex server, but application players (desktop and mobile) find it and are able to play my media; but I can’t access to the Plex server parameters.
Here the Plex’s logs:
User uid:    1001,
User gid:    100,
[cont-init.d] 10-adduser: exited 0.,
[cont-init.d] 40-chown-files: executing... ,
[cont-init.d] 40-chown-files: exited 0.,
[cont-init.d] 45-plex-claim: executing... ,
[cont-init.d] 45-plex-claim: exited 0.,
[cont-init.d] 50-gid-video: executing... ,
[cont-init.d] 50-gid-video: exited 0.,
[cont-init.d] 60-plex-update: executing... ,
Atempting to upgrade to: ,
Cannot get REALTIME clock frequency: Operation not permitted,
ERROR: cannot verify downloads.plex.tv's certificate, issued by ‘CN=DigiCert SHA2 Secure Server CA,O=DigiCert Inc,C=US’:,
  Issued certificate not yet valid.,
To connect to downloads.plex.tv insecurely, use `--no-check-certificate'.,
# Upgrade attempt failed, this could be because either #,
# plex update site is down, local network issues, or   #,
# you were trying to get a version that simply doesn't #,
# exist, check over the VERSION variable thoroughly &  #,
# correct it or try again later.                       #,
[cont-init.d] 60-plex-update: exited 0.,
[cont-init.d] 99-custom-scripts: executing... ,
[custom-init] no custom files found exiting...,
[cont-init.d] 99-custom-scripts: exited 0.,
[cont-init.d] done.,
[services.d] starting services,
[services.d] done.,
Starting Plex Media Server.,
recv: Connection reset by peer,
Error starting framework core for /usr/lib/plexmediaserver/Resources/Plug-ins-6c22540d5/LocalMedia.bundle.,
Error starting framework core for /usr/lib/plexmediaserver/Resources/Plug-ins-6c22540d5/PlexThemeMusic.bundle.,
Error starting framework core for /usr/lib/plexmediaserver/Resources/Plug-ins-6c22540d5/HTbackdrops.bundle.,
Server Version#: 1.21.1.3830
Finally found a solution here: Raspberry PI OMV5 and Plex
I used the tag :bionic for the image, instead of :latest and now it works correctly.
