on a foreign Network (100mbit/s) I cannot Play a 3 Mbit/s File in original Quality UNLESS I Transcode it (for example to Higher 8 Mbit/s).
Why is that? It is obviously Not bandwidth related. Codec is also fine for the Player (hevc).
I cannot Figure it Out. On Same Network, there is No Problem even at original Quality.
Well, that pretty much blew all my theories out. Everything should work in that setup.
Ok, let’s gather info that might narrow down what is the cause. When you play your file, what shows in the dashboard in Plex? (In a browser, log into Plex and in the upper right corner there is a yellow “Heartbeat” icon. Click it, and click on Dashboard).
Watch this screen (take a screenshot). What does it show when you attempt to watch the HEVC file on your Fire TV Stick?
well, the weird thing is. SAME setup today, same network. FLAWLESS playback even on original quality that refused to work yesterday.
no additional bandwidth usage, no other clients. I just cannot reproduce why plex sometimes just won’t play native quality and wants transcode even to a much higher bandwidth (here from 4 mbit/s original to 8 Mbit/s transcoded).
it is the strangest thing to me.
all files I have are very small (about 4-5 mbit/s) and should go through every WiFi without a problem. when I speedtest the network that refused to work yesterday, it shows me gigabit speeds in download and upload. same on server side. so it is definetely not a bandwidth problem for sure.
Would really appreciate it. I cannot figure it out here and it seems to be NO hardware or Bandwidth related problem. What is Rocketloader and the other stuff you mentioned?
Rocketloader is a technology used by Cloudflare to speed up page loading. However, this doesn’t work with all Websites, as I mentioned in another post (it’s been known longer, however it’s just a tech thing, not a bug).
WAF is a Web Application Firewall. You can read more about that here, but this is probably not the issue, especially if you don’t have one deployed.
A minimum TLS version would block devices trying to establish a connection via a lower TLS version. In that case, Plex would try to use the Plex Relay system. I think you would’ve noticed that.
Edit:
I’d try a reinstall (Plex Dance or another way) because I can’t remember what the culprit was. I’ll let you know though
Well… if you don’t know anything about Cloudflare, you’re probably not using it. Cloudflare is a CDN an domain registry. If you don’t have your domain at CF, or don’t have a domain in general, the steps above won’t apply to you and you’ll have to keep looking for another solution. Sorry
I have a domain, but I do not know if it uses cloudflare. I simply use it to point my IP to it (DDNS). so traffic is not routed through it, just the IP translates to that domain.
Is this your server you’re trying to play something from or you’re connected to a friends server remotely? Unfortunately, if this is someone else’s server you’re on the wrong side of the fence to troubleshoot this
Are we talking about the same file both times?
I agree. Everything you’ve said so far indicates this is something else
You need to be able to monitor the dashboard so you can verify if your remote access is configured properly and reliably.
If this is your server the best solution is to wait for a failure and gather your logs
Without logs this is mostly speculation and guesswork
